AutoPkgr Issue
  • January 25, 2016
  • 13 views
Trying to run this as everyone seems to rave about it, so i created a user in Caspers, full admin rights, stuck these details in the app, and i putt in our casper URL, and then the share point it auto found etc, but whenever I try to run a recipe i get this error?
Doesn't make sense, correct user and password, and the privileges are all correct?
Any advice?
bentoms
Forum|alt.badge.img+35
  • January 25, 2016
@betty02 heh.. Say hi to Nadine for me! Used to work @ Grey London about 5 years ago!
Anywho, the AutoPKGr should have pulled in the DP info from the JSS.
If you go into AutoPKGr > Folders & Integration > Configure JSSImporter.
Then maybe remove the bad DP & re-add?
  • January 25, 2016
@bentoms Haha will pass on your message! Yeah pulled it all through and failed, so did a remove and re-add and nothing, bit of a strange one! I hope this is as good as people make out! IF I get it working! Cheers buddy!
bentoms
  • January 25, 2016
@betty02 :) How does the DP look within the JSS?
