Big Sur Screensaver will not come on
Howard_Trevor
Contributor
Just put in a new small lab of 18 machines and they are on Big Sur. Cant get the screensaver to start on any of them no matter what I try. Tried a bunch of different manipulations of configuration profiles with energy saver changes but still no luck. Anyone have an idea? Hope I can find a solution because the screen goes black and its acting as if the machine is dead because it won't check into jamf, won't run policies, nothing... but yet wakes up immediately when I observe it in ARD or someone touches the mouse/keyboard. Any help is appreciated because I've got a few more new labs to do and don't want to be dealing with this on a much larger scale.
6 REPLIES 6
wdoty
New Contributor
Hello Howard_Trevor,
Screen Shot 2021-07-14 at 2.49.58 PM.pngI just did a test configuration profile and enabled the "Start screen saver after:" for 1 min and it worked on my test iMac.
This setting is in Configuration Profiles>>Login Window>>Options.
I'm using a Big Sur 11.4 iMac.
No luck on my end. Ive already got that set at 10 minutes, made a change for 1 minute to speed up my testing and still no luck. Tested on machines on 11.2 and 11.4
What are your energy saver settings?
nelsoni
Contributor II
From my testing, I have found that the profile only applies to the currently logged in user. The Mac will ignore the profile when sitting at the login window.
Howard_Trevor
Contributor
@nelsoni You sir seem to be correct. Its now recognizing the 1 minute change I made when a user is logged in but no change at the login screen. That is interesting. Is there any way around that? What in Big Sur changed that wasn't in Catalina because those machines run screen savers from the login screen. Im a little worried about burn in on these new machines. It doesnt take long for these screens to start burning in the login boxes, seen it on a few machines with the connect keyboard and mouse message at the login screen being burnt into the background when a user logs in.
Yes, you guys are correct. I was testing this on an iMac that was already logged in.
We are currently have the iMacs set to turn off the display after a set amount of time.
Sorry for the confusion
