Bluetooth acting up, I think...
  • February 3, 2015
  • 4 replies
  • 36 views
Scenario: Creating an image with AutoDMG, using said dmg for Imaging with Casper Imaging and netboot makes the client report "no support for BLE".
Using the exact same image with DeployStudio and a QuickAdd.pkg makes the same hardware report "support for BLE"
Any help appreciated.
Yosemite 10.10.2, Casper Suite 9.63, DeployStudio 1.6.12, AutoDMG 1.5.2
//Patrik
davidacland
  • February 3, 2015
Its probably a question for JAMF support as it does sound like a Casper Imaging specific problem and you're up to the latest JSS patch.
Just in case, does it behave the same with 10.10.1?
  • February 3, 2015
@davidacland
You're probably right, but I though I'd see if the community had anything to say 'bout this first.
...and no I haven't tried this on any other version, don't work with old stuff ;-)
//Patrik
  • May 20, 2016
Using Composer I created a pkg for El Cap to use on all our MacBooks. Some how I have clobbered bluetooth and the ability to access Apple tv as well as mobile accounts available at restart. My macbooks will only restart in local admin. Any advice??
Kim
davidacland
  • May 20, 2016
Sounds like a problematic package. What's in it and how did you make it?
