Built in Apps and Smart Groups
  • January 28, 2020
  • 13 views
BGSICTSupport
Is is possible to create a smart group containing devices that don't have the built in iOS apps installed (e.g. Calendar)?
I've tried just specifying 'Calendar' in the App Name field but that doesn't work, I assume because when you look at the Apps section of the device built in apps are not listed.
Thanks
1 reply
cdenesha
  • February 3, 2020
I don't think it is possible, for exactly the reason you put forth.
