Bypass Proxy Settings
  • July 24, 2015
  • 13 replies
  • 84 views
msample
Have there been any other attempts to automate adding: swcdn.apple.com, swdownload.apple.com, swquery.apple.com,swscan.apple.com, to the "Bypass Proxy Settings" field?
davidacland
  • July 24, 2015
Have you checked out this
msample
  • July 24, 2015
@ davidacland Yes, great post, and thanks for sharing. I've referenced this for auto-populating the URL proxy fields (i.e., http and https). But I'm working with the task of auto populating the huge field beneath. Researching which plist sees this field and how to write to it via script. This is an interesting alternative with not being having APNS in place. Any ideas?
  • July 27, 2015
I use the networksetup command for this.
networksetup -setproxybypassdomains $networkservice "$EXCEPTION1" "$EXCEPTION2" "$EXCEPTION3" "$EXCEPTION4" "$EXCEPTION5" "$EXCEPTION6" "$EXCEPTION7" "$EXCEPTION8"
msample
  • August 12, 2015
@Josh.Smith Josh can I auto populate this into the ByPass field? (ex: networksetup -setproxybypassdomains $networkservice "swscan.apple.com" "swquery.apple.com" "swcdn.apple.com" "swdownload.apple.com" ?)
  • August 12, 2015
Yes you can hardcode the values in like in your example. You can also hardcode the networkservice name (example: "Thunderbolt Ethernet") if appropriate.
msample
  • August 12, 2015
@Josh.Smith I thought to first test populating the field just through terminal, but I ran into this error:
  • August 12, 2015
@msample Try this (you'll need to enter your network service name, it may not be "Display Ethernet")
sudo networksetup -setproxybypassdomains "Display Ethernet" "swscan.apple.com" "swquery.apple.com" "swcdn.apple.com" "swdownload.apple.com"
Before:
After:
msample
  • August 13, 2015
@Josh.Smith Dropped in the Network Service name (i.e., sudo networksetup -setproxybypassdomains "Thunderbolt-Ethernet" "swscan.apple.com" "swquery.apple.com" "swcdn.apple.com" "swdownload.apple.com"). but the error is the same...
I'm wondering if I add more specific direction with the proxies tab... (i.e., sudo networksetup -setproxybypassdomains "Thunderbolt-Ethernet" "Proxies" "swscan.apple.com" "swquery.apple.com" "swcdn.apple.com" "swdownload.apple.com") ???
msample
  • August 13, 2015
Just ran another test directed through the "Proxies" tab...no success populating the BP field....
So targeting the network database is the key component
  • August 13, 2015
The issue is likely the hyphen in
To get the list of valid options on your system for that value run this:
networksetup -listallnetworkservices
My MBP connected to an Apple display gives these networkservices:
*Bluetooth DUN 5
Display Ethernet
Display FireWire
*Wi-Fi
*Bluetooth PAN
Thunderbolt Bridge
So I could run any of these (or ideally use a script that pulls the names in dynamically and configures them as desired):
networksetup -setproxybypassdomains "Thunderbolt Ethernet" "swscan.apple.com" "swquery.apple.com" "swcdn.apple.com" "swdownload.apple.com"
networksetup -setproxybypassdomains "Wi-Fi" "swscan.apple.com" "swquery.apple.com" "swcdn.apple.com" "swdownload.apple.com"
msample
  • August 14, 2015
@Josh.Smith Works beautifully from the command line, Josh. Building a script to auto-populate the field and will test further.
msample
  • August 21, 2015
Figured out how to make it populate.
Created a policy, checked the "Custom" button...
- Custom Event jamf policy -trigger thenameofyourpolicy
- Execution Frequency once per user
- Recurring Check-in
Create a script to attach to the policy (#!/bin/sh not #!bin/bash), and add the Files and Processes payload.
In the File and Processes payload, configure the "Execute Command" field with:
networksetup -setproxybypassdomains "Thunderbolt Ethernet" .local 169.254/16 swscan.apple.com swquery.apple.com swdownload.apple.com swcdn.apple.com*
Tested not attaching a script to this, but the configuration never populated the bypass proxy field.
  • August 28, 2019
Is there anyway to set the proxy bypass domains on a global system level rather than network service by network service?
