Posted on
01-17-2018
08:57 AM
- last edited
4 weeks ago
by
kh-richa_mig
I am in the process of on-boarding a college into our JAMF Pro instance. I gave the department Admins a Quick-add package to enroll existing Macs. Turns out, they are caching a custom image for their log in screens at /Libraries/Caches. That is getting deleted at enrollment. Is there some place I am not aware of to prevent this from happening? And, I have never cached anything there in an image before-is there a better place for them to stash that image?
TIA,
/randy
Solved! Go to Solution.
Posted on 01-22-2018 09:21 AM
I actually ended up figuring this out. I had an Update Inventory Policy and it was set to delete user and system caches. So at enrollment, it ran and nuked it. It was not the quick add package but my global policy. Since I have implemented Sites, these little things keep popping up. My next project is to audit all my policies and see what potential fallout there may be for people we take on in our JAMF instance. Most of the departments are still using Monolithic imaging so these things will happen. I have never put anything in caches so I never considered that the policy would cause the issue.
Thanks @scottb
/randy
Posted on 01-17-2018 01:47 PM
Are you talking about /Library/Caches/com.apple.desktop.admin.png?
That file is somewhat volatile as that dir can empty with a Safe Boot, maintenance apps, etc.
It's not something you can change that I know of.
Not sure if/why QuickAdd would nuke that - but maybe someone else has an idea.
Thanks @scottb
/randy
Posted on 01-22-2018 10:23 AM
Good to hear, @Randydid. Usually, it's "me" and the growing number of possibilities that lies buried the answer ;)
Scott
