Can Jamf School and Jamf Pro use same VPP token?
  • October 9, 2023
  • 4 replies
  • 46 views
We use Jamf School to manage iPads and will be using Jamf Pro to manage Mac Minis for a high school computer lab. Can these two use the same VPP token and the same Apple ID? In my research, I'm finding that we can use the same Apple ID but need to create a different location with a seperate VPP token. Is this correct?
Best answer by RaxiaDK
You need to create a location per MDM server. And I always create a location for spare license
RaxiaDK
  • October 9, 2023
AJPinto
  • October 10, 2023
No, but you can have multiple MDM tokens and split licenses between your MDM tokens.
  • October 10, 2023
Can I use the same apple ID for pro and school?
RaxiaDK
  • October 10, 2023
For APNS cert yes
