Casper Infrastructure on AWS
  • January 7, 2016
  • 0 replies
  • 9 views
I finally go the go ahead to move our JSS to AWS. For now, I am simply going to stand up the instance and begin a migration plan. Wanted to know if anyone in the community has gone through this process and could point me in the direction of some helpful documentation, tips, best practices, and lessons learned.
My Goal:
configure external JSS up and running on AWS instance .
Configure Clients to check in to Cloud JSS
Enable communication between internal JSS and External, opening necesary ports.
Create Cloud DP Finally, migrate completely to Cloud JSS and make primary JSS for all my endpoints.
Concerns:
Casper Remote
Master DP
Netboot / SUS Failover DPs
JDS Device Enrollment Certs
Replication
Thank you in Advance
