Is there a way to remove a configuration profile that has a wifi configuration without forcibly removing the device from that network? We're a school district, and each teacher has a MacBook Air, so they're all over the place, making physical access difficult.
I'm breaking a configuration profile down into its parts to make it more modular. One of these new parts is a wifi profile, which I've deployed to a guinea pig while I was there in person. I added that device to the wifi profile's scope and made sure it applied. However, upon removing the old profile, the device was kicked off of wifi and didn't reconnect.
Restarting the wifi doesn't fix it, and neither does restarting the computer, despite the new wifi profile's presence. I could easily physically enter the wifi password, but these devices are everywhere, literally miles apart. It seems odd to me that Jamf forcibly removes the credentials for the wifi when the configuration profile is disabled, regardless of the other wifi profile.
Maybe I can add an entry to keychain? I would prefer not getting the users involved, if at all possible.
