Changing Default profiles and SIP
swright_mm
New Contributor III
Is there a way to change the Default user profiles in EL Capitan so that When a domain user logs in they wont receive the permission errors? Configuration profile doesn't allow me to do all the things I need to for the domain users default profile. I tried disabling the SIP and then changing it, all of my settings stick but the user loses permissions. I don't want to have to chown every system after imaging it to make sure that the users have there permission.
5 REPLIES 5
davidacland
Honored Contributor II
Hi, you don't need to disable SIP to write into the user template, although it should be avoided unless there is no other option.
In most cases, adding login policies with scripts can do what you need and avoids having to modify the base OS.
If you are getting permissions errors, it sounds like something is wrong with the permissions on the additions to the user template so if you fix it there, it will work for new users logging in.
swright_mm
New Contributor III
@davidacland Usually on other OS such as Yosemite and older I would modify the User template to be able to make the image exactly how i'd like it. But now when I do the same thing i get these errors. When I tried to do it with SIP enabled it allowed me to make changes but when a domain user logged in it didn't show those changes. After I disabled SIP and made those changes again, I logged in as the domain user and it worked. But only problem was that the permissions to the user's home folder werent there so I had to chown it for them to have there permissions.
Legendary Contributor III
You should be looking at deploying a DMG using the FUT (Fill User Template) option enabled on it to to deploy the changes to the User Template. Or script changes in your image to that folder before capturing it. I'm not sure how you were doing the same changes before, but those are the only real ways to do it that aren't going to mess things up or just block you altogether.
As @davidacland mentioned, the /System/Library/User Template/English.lproj directory (or whichever languages you need to affect) are writable in 10.11. There are existing exclusions in SIP to allow those to be modified. So again, I have no idea how you've been trying to edit that location, but you should rethink it since its possible to modify it without disabling SIP.
ajtcable
New Contributor II
I've found that creating a default account and using a script that copies changes to the english.lprog works very well, even in El Capitan. The only hitch is you must delete the key chains created in the default account. Otherwise, you get login item key chain issues. There is a group of scripts out there that can do this work for you if you follow the procedures correctly. I've had no problem creating a preconfigured environment for my guest and domain users. This technique is robust and allows for configurations specific to department, et al. One issue is that to fully define an environment, you have to use monolithic images. Thin imaging and heavy scripting will not accomplish the same goal without a ton of front end work. As I am not a heavy scripter, I can do the work as quickly in this fashion. SIP has only caused me issues on the netbooting of my JAMF and Deploy Studio shells. And that is where I am doing most of my experimenting at this time.
ajtcable
New Contributor II
I should clarify that you want to delete the key chains from the english.lprog, not the default account. I leave the default account in tact so that as things are updated, I can simply make minor changes to the default account, then run the script in root and delete the key chains again. Then, as in my labs, most are configured for guest user use, the environment is changed for the next user to log in. Keep in mind, this DOES NOT alter existing domain or local users. I've not yet experimented with FEU Fill Existing Users for this concept.
