- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
Posted on 12-14-2021 12:22 PM
Hello All,
I'm pretty new with Jamf and I need some help. Strange things are happening when the computers check-in with Jamf. When the Macs check-in they will blink, which I assume is normal behavior. When this blink happens users are reporting that if they have any application windows minimized in the dock they will maximize on their own. The other, more troubling issue is that if the check-in happens while they happen to be in a video call both incoming and outgoing audio will drop out and the users have to leave the meeting and come back. The first issue is an annoyance but the second one is a real problem. I have the check-in set to the maximum 60 minutes but these issues still happen. Is there anything I can do to make the check-in less intrusive. Is there a setting where I can make it check in once per day unless I force it, for example. Any help would be appreciated.
Solved! Go to Solution.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Posted on 12-14-2021 01:53 PM
So Im not sure what the "blinking" is but that is not normal. Check the policies to see what is happening, if there is an install that is set to ongoing that may be causing that.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Posted on 12-14-2021 01:06 PM
Any policy that has "Recurring Check-In" or "Network State Change"? Maybe change it to something less frequent.
In Jamf, look at the computer's History > Policy Logs to see which policy got triggered that caused the issues.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Posted on 12-14-2021 01:12 PM
Thanks. Finding the correct tuning of Frequency vs Trigger.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Posted on 12-15-2021 04:54 AM
Thanks for everyone that helped with this. I had an ongoing policy to install a profile running every hour.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Posted on 12-14-2021 06:27 PM
Make sure you don't have a policy that has a recurring check-in trigger with an "ongoing" execution frequency.
