Classlink SSO for Jamf Pro
  • May 24, 2024
  • 38 views
Has anyone successfully implemented Classlink as their Single Sign Out for Jamf Pro?
@zinkotheclown ,
While there's no direct mention of widespread success stories, the discussion suggests Classlink SSO with Jamf Pro can be achieved. It's recommended to search for additional resources online or within the Jamf Nation Community for more detailed guides or troubleshooting experiences.
In the Jamf Pro settings, navigate to System > Single Sign-On. Enable Single Sign-On Authentication and choose Classlink from the Identity Provider dropdown menu (if available).
You'll need to configure Classlink to act as the Identity Provider (IdP) for Jamf Pro. This likely involves setting up a connection or application within Classlink specifically for Jamf Pro.
Ensure your versions of Jamf Pro and Classlink are compatible for SSO functionality. Double-check all security configurations on both platforms to ensure a secure authentication flow. Thoroughly test the SSO integration after configuration to ensure users can seamlessly access Jamf Pro through Classlink credentials.
  • May 29, 2024
@zinkotheclown ,
I appreciate your response, but there is no option for ClassLink in the SSO drop down menu.  Is this AI generated?
