Cloud Distribution Point - not failing over?
  • March 27, 2016
  • 27 views
Where do you set the cloud DP as the failover? When I edit my various DPs, and view the list of Failover DPs, the cloud DP is not an option to select.
I have my internal DP set as master but cannot select my cloud DP as a backup?
Best answer by Aziz
Hi @Lucasw, having a Cloud DP as a fail-over distribution point is not possible at the moment . Here's a feature request you can vote up!
https://jamfnation.jamfsoftware.com/featureRequest.html?id=2906
  • March 27, 2016
  • March 27, 2016
Thanks! Im surprised this isnt already a feature.
