CMD + L for lock screen
  • June 21, 2019
  • 5 replies
  • 52 views
Is there a way to mass configure Macs to change the lock screen short cut to CMD + L?
  • June 21, 2019
I haven't found one. What i do use is "hot corners" and set my screensaver to start when i drag my mouse to the lower right corner.
tfenna
  • June 21, 2019
This should do it
sudo -u $3 defaults write -g NSUserKeyEquivalents -dict-add "Lock Screen" -string "@l"
Though I found I needed to reboot for it to work globally after applying
Until I rebooted it would only work in some applications
  • June 21, 2019
Command + L is a very common key shortcut to go to a browser's URL Bar. Why not just teach your users about the builtin key command - Control+Command+Q?
  • June 21, 2019
If you are not paying attention and hit Option+Command+Q you just quit the current app, so I can see why you might want to map a different series of keys. Command+L is probably not the best choice to lock the screen because of what TimArnold stated above.
  • June 22, 2019
I'd like to echo @TimArnold 's comment.
Unless there's an accessibility issue, I'd err on the side of keeping the defaults so that users aren't confused when they're outside of the managed bubble.
