I know apple recommends using configurator for cart based iPads still but this is my plan instead.
We will have 20 iPads each for 1st grade, 2nd grade and 3rd grade. They will be shared among 4 classes/grade level. I will create one Apple ID for each grade level set. Enroll, name, and restore a back up with the appropriate Apple ID using configurator. Then use managed distribution to deliver the apps to the iPads. I can then assign an app to the appropriate Apple ID and push that app to each of the 20 iPads in that grade level. I would assume that it would only use one license under VPP since that is based on user and not device but as long as I purchase the appropriate number of licenses for the app I should be covered correct?
Can anyone see any reason to NOT do it this way and still use configurator install all of the apps?
