Posted on 12-09-2020 05:42 AM
I have received a notification asking me to change the password method for user-initiated enrollment for the jamf admin account to a random password. I have set the password to a specific password so that I know what it is in case I ever have to use it in an emergency, so I don't want to change to a randomized password. Can anyone explain why it forces you to set the password to random and how do I get rid of the notification?
Solved! Go to Solution.
Posted on 03-01-2021 06:56 AM
I ended up setting the management account password to random. I then used another policy to create a local admin account on the computer.
Posted on 02-10-2021 12:55 PM
did you figure this out?
Posted on 02-10-2021 01:04 PM
It's more secure to use a random password for each device instead of the same password for all devices. The management account has privileged access. As a general security control, you should not have common admin account credentials on every device.
I don't know how to get rid of that notification, but you can just continue to ignore it if you want.
