Conversion from KE to PSSO
  • December 2, 2024
  • 36 views
Eltord
Hey ya'll,
I am currently in the middle of developing the process for converting my users over from using the Kerberos Extension to using Platform SSO on our Macs. I've got the profiles ready and all the local apps and such prepped to deploy, but when I perform the process I run into a few errors during the PSSO registration process. In particular I run into an issue at the end of the PSSO registration where it states that the "Sign in is currently unavailable", which does not happen when I enroll a device and have it go direct to the PSSO process and excluded from any of our KE profiles/policies.
I was wondering if there is anyone here that went through the migration process and if anyone had any tips/tricks as to what they did to ensure a smooth user experience. I have every other piece ready to go and working flawlessly, just need to get my users in there and as we all know, the easier the experience is, the more likely users will do it quickly.
Thank you!
1 reply
Did you find any solution for this? I'm stuck with the same issue at the moment.
Help is appreciated!
