Creating a Smart Group based on list of serial numbers using the API
  • February 21, 2023
  • 105 views
I'm looking for a way to create a Smart Group in Jamf based on a large list of serial numbers via the API. For example, when I have a large amount of end of lease iPads to decommission, I'd like to be able to quickly create a Smart Group containing those serials using the API, rather than creating a Smart Group via the GUI and manually inputting a massive list of serials.
I've seen some helpful posts explaining how to create a smart group via the API, just checking if someone has achieved something similar before I look into this further.
Forum|alt.badge.img+20
  • February 21, 2023
Maybe I am not understanding, but why do you need a Smart Group? How about a Static group. If you can use a Static group, you can use MUT to upload assign the devices by serial number.
jamf/mut (github.com)
  • February 22, 2023
Thanks for the reply! I've just tested this process and it worked perfectly for what I needed.
