Creating a USB Bootable Drive - Simple Process
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
Posted on 09-02-2013 07:57 PM
Is there a simple process out there that allows the external USB drive to just boot via Option Boot and the process installs the OS and the applications without any user interaction?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Posted on 09-02-2013 11:04 PM
Yes.
Create a NetBoot-like set on the USB drive with auto-login turned on for (prob the root user) with Casper Imaging as set to open on login, save credentials of a imaging user in the keychain, set up an autorun image in Casper, and voila! If you need more details, I am sure the community can provide more specific advice.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Posted on 09-03-2013 06:34 AM
The simplest way I know is to boot into the recovery partition and choose to do a re-install but set the target disk to be your USB drive.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Posted on 09-03-2013 07:17 AM
Thanks for the advice guys. I guess there is really no other way of making this a little more seamless.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Posted on 09-03-2013 07:47 AM
DeployStudio.com
