Crowdstrike - Permission Denied
  • August 6, 2024
  • 5 replies
  • 58 views
We are looking at testing CrowdStrike for mobile, we currently use Cisco Security (DNS Security & Endpoint Visibility)
I have created a new CS profile and when I first scoped it to one of my test devices I get Permission denied,  I can only get this to successfully install after I remove Cisco Security,  any suggestions on why both config's wont work on a single device,
appreciate it
  • August 7, 2024
I too am getting ready to install products similar to these for better endpoint visibility in the coming months; it makes sense to me that the you wouldn't want too and it is a bad idea© as they say to install two of these kinds of products at once. Wouldn't surprise me if the cisco product, sees crowdstrike and kills it. One at a time, I'd think.
AJPinto
  • August 7, 2024
I'm guessing they both hook into a system extension that does not allow for multiple configurations. Can you provide the configuration profiles you are deploying?
  • August 14, 2024
Any update?
  • August 16, 2024
Hey, sorry for the delay but this was exactly the issue, once I got our security team to watch the logs as we implemented on a test device he was able to see Cisco kill the install process from CS.
  • August 16, 2024
Hello All,  So after some more testing and working with my security team , we were told to no longer test CrowdStrike and will continue with our Cisco AMP and Umbrella product.
