Customize Jamf Pro
  • May 8, 2024
  • 18 views
Narmijarv
Is there any way to customize the Jamf Pro administration interface with colors, background or logo ? (Except just dark and light mode)
When working with 3 different Jamf Pro enviroments back and forth, it is easy to make changes in the wrong environment.
Best answer by jamf-42
Use Arc Browser and setup a boost.. random link https://allthings.how/how-to-use-boosts-in-arc-browser/
RaxiaDK
  • May 8, 2024
no, you can install plugins to your browser to change things.
jamf-42
  • May 8, 2024
Narmijarv
  • May 8, 2024
Thanks for the tip. I will look into this. Even if I have tried Chrome themes and Chrome color changes for diffrent chrome profiles. It do not help much. When you are focused on something you won't noticed if the browser "fram" is in a different color. I need to have the whole background in a different theme in Jamf Pro. Maybe there is a plugin for that.
