Declarative Management
xEpicFail_O_o
New Contributor II
Is anyone currently having issues with Declarative Management and its rollout? I'm receiving a command failure with the following on all my systems which hit the base requirements of Declarative Management.
Command: DeclarativeManagement
Error/Status: JSON text did not start with array or object and option to allow fragments not set. around line 1, column 0.
JAMF Version: 10.42.1-t1667311080
MacOS: 13.1
Enrollment Type: DEP
Any guidance would be greatly appreciated.
4 REPLIES 4
Javier
New Contributor II
New Contributor II
Hi EpicFail, this is PI-110700. (Product issue)
It will give a message but wont be in the way of other management commands.
iroman
New Contributor
@Javier this a JAMF or Apple "Product Issue" - Don't like seeing this failed command
Javier
New Contributor II
New Contributor II
Not sure who's to be honest, maybe best to verify with support@jamf.com
xEpicFail_O_o
New Contributor II
Thank you so much @Javier for the information. Was beating my head over this for the last few days. Glad to know that it's a known issue at least and not something wrong with my setup.
