defaults read Extension Attribute inconsistent results on 10.10 and 10.11
  • July 12, 2016
  • 10 replies
  • 80 views
Hi all
We have an EA in place to retreive the Apple update server CatalogURL that's set on each Mac, it works consistantly on all our 10.9 machines but i'm getting incosistent results from 10.10 and 10.11 machines.
We're pushing out the CatalogURL in a computer level Configuration Profile so it adds the CatalogURL to /Library/Managed Preferences/com.apple.SoftwareUpdate.plist and
not to /Library/Preferences or /var/root/Library/Preferences
If i run jamf recon the EA reports back with no result on about half of the machines if i then run the command directly on that Mac in terminal (the plist definitely has a CatalogURL key within it)
As root defaults read /Library/Managed Preferences/com.apple.SoftwareUpdate CatalogURL i get Segmentation fault: 11
as admin sudo defaults read /Library/Managed Preferences/com.apple.SoftwareUpdate CatalogURL i get no result
as admin without sudo defaults read /Library/Managed Preferences/com.apple.SoftwareUpdate CatalogURL i either get the CatalogURL successfully on some machines and get Segmentation fault: 11 on others
it seems to be permission related as i can copy the plist to the Desktop and read from it ok from there. As this is running as root in an EA is there anything i need to be aware of to make this work 100% on 10.10 and 10.11 ?
here's the EA
if [ -f /Library/Managed Preferences/com.apple.SoftwareUpdate.plist ]; then
SWU=`defaults read /Library/Managed Preferences/com.apple.SoftwareUpdate CatalogURL`
echo "<result>$SWU</result>"
echo "<result>No managed plist</result>"
Best answer by franton
Try this instead. It'll output "None" if the key isn't managed, or it should output the CatalogURL key contents.
#!/usr/bin/python
# EA to show if Software Updates are managed or not
import CoreFoundation
domain = 'com.apple.SoftwareUpdate'
key = 'CatalogURL'
key_value = CoreFoundation.CFPreferencesCopyAppValue(key, domain)
print "<result>{}</result>".format(key_value)
As has been explained to me by @bentoms and others, you should use the OS API to read out the key as with defaults, you get the contents of the file/memory cached copy which may not be what the OS is using if a profile is installed.
  • July 12, 2016
or is than alternative way to get the CatalogURL ?
  • July 12, 2016
@May On my home system (10.10.5), I get the correct results with defaults read /Library/Preferences/com.apple.SoftwareUpdate CatalogURL.( results are from Reposado VM at home)are you running Munki on any of your systems? IIRC Munki uses /Library/Managed, but could be other applications also
hth
Larry
Larrys-iMac:$ sudo defaults read /Library/Preferences/com.apple.SoftwareUpdate CatalogURL
**http://10.19.1.9/content/catalogs/others/index-10.10-10.9-mountainlion-lion-snowleopard-leopard.merged-1_home.sucatalog**
Larrys-iMac:$ defaults read /Library/Preferences/com.apple.SoftwareUpdate CatalogURL
  • July 13, 2016
This is how I do my Apple Software Update Server Extension Attribute:
SWU=`defaults read /Library/Preferences/com.apple.SoftwareUpdate CatalogURL`
Make sure you wrap the defaults read statement with a backtick `
Edit: Just tested your script. Works for me.
  • July 13, 2016
Thanks @stevevalle @LSinNY
We're using Apple update server.
Looking at the plist in /Library/Preferences there is no CatalogURL key in there and /var/root/Library/Preferences/com.apple.SoftwareUpdate.plist does not exist.
I think because we're pushing it out via a config profile it only writes to /Library/Managed Preferences/com.apple.SoftwareUpdate.plist,
I have the command wrapped in backticks, i'll try enclosing it with double quotes and other ways to see if that makes a difference, i do still think it's permissions related as if i move the plist to the Desktop the same script reads from it with no issue.
Forum|alt.badge.img+23
  • July 13, 2016
#!/usr/bin/python
key = 'CatalogURL'
  • July 13, 2016
Hi @franton
It's good to know this is the best approach
I've just tested it and all the Macs are consistently reporting the CatalogURL correctly, i then remove the CatalogURL config profile and re-test and the script reports "none" as expected,
thank you so much!
  • July 13, 2016
You're welcome. I got the info from macmule and frogor on the slack instance.
bentoms
Forum|alt.badge.img+35
  • July 13, 2016
@franton dammit! Giving away part of my JNUC talk.
Haha.
  • September 21, 2016
This is great... 1 quick question...
I modified this slightly to return the plist entry for file location for Dropbox... However I assume the script itself is not run as the currently logged in user... Is there a way in python to run this as the current user?
!/usr/bin/python
EA to show dropbox folder location
domain = 'com.getdropbox.dropbox.plist'
key = 'NSNavLastRootDirectory'
JevermannNG
  • January 31, 2023
#!/usr/bin/python
key = 'CatalogURL'
Is there a way to run this in BASH ?
Thank you!
