Posted on
07-16-2018
06:12 AM
- last edited on
03-04-2025
08:32 AM
by
kh-richa_mig
Need some updated info about how to deploy Code 42 Enterprise with Jamf Pro.
Can't find any info how to deploy Code 42(only old ones..)
Thanks!!
Posted on 07-16-2018 07:06 AM
Is the client you are installing lower then v6.5 or v6.5 and newer? The installer should be the same for each, but the customization for your environment is different depending on which client you are deploying.
Posted on 07-16-2018 07:12 AM
This article got me started. http://docs.jamf.com/technical-papers/casper-suite/crashplan/9.0/Deploying_the_Code42_CrashPlan_App.html
Posted on 07-16-2018 08:39 AM
Code42's support page is getting harder and harder to navigate but those two links should contain everything you need. TL;DR: Get a deploy.properties file, install it to /tmp/mountpt/Code42CrashPlan before running your 6.5 installer pkg.
Posted on 07-16-2018 01:23 PM
I had to reach out to code42 support to get ours working, we had an issue... their support rocks!!!
C
Posted on 07-24-2018 02:49 AM
Yes! Had some help from Code42 support They rocks!
