Posted on
11-18-2020
04:04 AM
- last edited
Tuesday
by
kh-richa_mig
We have several M1 chip MacBooks that we want to deploy. How can we push and ensure the Rosetta policy to install (softwareupdate --install-rosetta) gets installed before all the other policies (i.e. Office, TeamViewer, etc.) ? If not, the other installs will fail. I can create a separate policy for each application that has a different scope but that becomes a pain.
Solved! Go to Solution.
Posted on 11-25-2020 05:52 AM
So, I got this working. What I did was create a Smart Group for M1 machines. Then, then only policy that I had that kicked off as Enrollment complete is one that installs Rosetta. If it's not an M1 then it kicks off the rest of the policies. Once Rosetta is install I have an event trigger that fires off the rest of the policies. So far it's worked. This allows me more flexibility to quickly change around policies.
Posted on 12-01-2020 12:40 PM
@mwu1876 So how did that work if the Jamf binary won't enroll the machine without Rosetta? Meaning, policies won't run if it's not enrolled and it can't install Rosetta as a policy without being enrolled.
Posted on 12-01-2020 12:52 PM
@Kristopher Jamf running 10.25.2 or 10.26 should natively support Apple Silicon, and enrollments should work fine. I haven't gotten my M1 yet to test/confirm, but that's what the Jamf documentation states.
Posted on 12-01-2020 01:10 PM
@Kristopher So if you ask Jamf to upgrade you to 10.25.2 it will enroll M1 machines. That's what I did. The upgrade too minutes and then I was able to enroll them. I still had to push out Rosetta. 10.25.2 supports M1. They sent, I believe, an email that said it's not a automatic deployment and that you have to request the version.
Posted on 12-02-2020 05:53 AM
Posted on 12-02-2020 03:04 PM
@mwu1876 That is what I did as well, I made Rosetta run initially and reported it installed successfully. The policies after still fails to install and says Rosetta is required and needs to be installed. Not sure if a computer needs to be rebooted first after a Rosetta install.
@pbowden I did not update the OS, testing this out a fresh out of the box M1
Posted on 12-02-2020 07:24 PM
What criteria did you guys use to flag apple m1 chip macs for your smart group?
Posted on 12-02-2020 07:32 PM
@txhaflaire how would you package the scrip on prestage? So this will ignore intel machines and only install on m1. looks good
arch=$(/usr/bin/arch)
if [ "$arch" == "arm64" ]; then
echo "Apple Silicon - Installing Rosetta"
/usr/sbin/softwareupdate --install-rosetta --agree-to-license
elif [ "$arch" == "i386" ]; then
echo "Intel - Skipping Rosetta"
echo "Unknown Architecture"
Posted on 12-02-2020 07:38 PM
@mwu1876 What criteria did you use to flag apple m1 chip macs for your smart group?
Posted on 12-02-2020 08:39 PM
you can try the criteria Architecture Type is arm64
Posted on 12-02-2020 10:50 PM
@dmiguel Just set it as a postinstall script when creating your package and that simply it is.
Posted on 12-03-2020 03:23 AM
Posted on 12-03-2020 03:57 PM
I really hope Rosetta becoming dysfunctional after an OS update is a bug, not a feature.
Posted on 12-09-2020 02:44 PM
You can make a smart group that filters ARM Architecture.
Posted on 12-12-2020 10:02 AM
@mwu1876 can you describe your event trigger that kicks off after the enrollment policy installs rosetta?
is the event trigger a policy with a script, and the script then calls each policy using the (jamf policy -id ????)
Posted on 12-12-2020 10:21 AM
You know why Self Service in M1 already with Rosetta Installed does not work when installing Intel Apps, it remains in a loop but does not install anything.
Posted on 12-12-2020 10:22 AM
I don't know how big Rosetta2 is but if it is less than 1GB arguably it should be installed as standard, especially as all other OS components are. (Apple has not had a customisable OS installer for a very long time.)
The issue about it being 'broken' again when the OS is update is a bigger problem and frankly I consider this to be a bug, it should see it already installed and do an update for Rosetta2 as part of the OS update. Just like an OS update may also update Safari.
To fix Apple's mess here, does anyone know how to check the version of Rosetta2 that is installed? We could then have a script which compares the version to the OS version and hence then if needed trigger another Rosetta2 install command. Perhaps looking at a date stamp of an OS file would be a way? That is if the OS file is 'newer' than the Rosetta2 file then trigger another Rosetta2 install.
It would be helpful if someone could list the file paths for the various Rosetta2 components.
Posted on 12-12-2020 10:32 AM
Sure. So here's how I have everything work.
1. Smart Group with the criteria for Architecture Type is arm64
2. You will want to create two scripts. The first is simple script to install Rosetta
3. The second script is to trigger all the remainder policies using sudo jamf policy -event trigger unless you're using DEPNotify.
4. Next I created a policy that only runs with the smart group for M1 processors. The triggers are Enrollment and a Custom Event called install-rosetta (just in case I need to use it manually or via another script).
5. Then I created a second policy to run after Rosetta is installed which fires off the second script that runs the remainder of the policies. That one is only set to run via Custom Event start-enrollmentinstallers.
So far everything is working. I'm testing out DEPNotify which does change how this is done but for now, it's fine.
Posted on 08-17-2021 11:51 PM
Wow, this is pretty freaking awesome. Thanks, for sharing this. I am going to give this a try. I'm curious how to execute was workflow like this utilizing DEPNotify. Fascinating!
08-18-2021 12:30 AM - edited 08-18-2021 12:30 AM
Use a script to install rosetta, and trigger it 'Before' other tasks in your provisioning policies. For example, this is our depNotify-based policy that's triggered by Enrollment. At the end (cut off from the screenshot) is our customized depNotify-starter script, running 'After' everything else.
Posted on 12-17-2020 11:01 AM
For prestage enrollments you can create a prestage package which runs a simple script with something like below for instance
Did you actually try this?
I used Composer to create an "empty" package with a preinstall script inside. However when running this on an M1 mac without Rosetta, it says:
To install "package", you need to install Rosetta. Do you want to install it now?
so I'm back to square one.
Posted on 12-17-2020 11:33 AM
@michael.madsen
I use the following script (credit to rtrouton) in a Policy with the "Enrollment" trigger. This is scoped to all machines as the script has logic to exit if it detects an intel Mac. The policy name begins with < _00 - > forcing it to run 1st in our enrollment process. Seems to work extremely well, but of course more testing is needed. Hope this helps.
# Installs Rosetta as needed on Apple Silicon Macs.
exitcode=0
# Determine OS version
# Save current IFS state
OLDIFS=$IFS
IFS='.' read osvers_major osvers_minor osvers_dot_version <<< "$(/usr/bin/sw_vers -productVersion)"
# restore IFS to previous state
IFS=$OLDIFS
# Check to see if the Mac is reporting itself as running macOS 11
if [[ ${osvers_major} -ge 11 ]]; then
# Check to see if the Mac needs Rosetta installed by testing the processor
processor=$(/usr/sbin/sysctl -n machdep.cpu.brand_string | grep -o "Intel")
if [[ -n "$processor" ]]; then
echo "$processor processor installed. No need to install Rosetta."
# Check Rosetta LaunchDaemon. If no LaunchDaemon is found,
# perform a non-interactive install of Rosetta.
if [[ ! -f "/Library/Apple/System/Library/LaunchDaemons/com.apple.oahd.plist" ]]; then
if [[ $? -eq 0 ]]; then
echo "Rosetta has been successfully installed."
echo "Rosetta installation failed!"
exitcode=1
echo "Rosetta is already installed. Nothing to do."
echo "Mac is running macOS $osvers_major.$osvers_minor.$osvers_dot_version."
echo "No need to install Rosetta on this version of macOS."
exit $exitcode
Posted on 12-17-2020 12:15 PM
@mrheathjones
Thanks, but I'm not willing to go this route just yet, as it is too much of a "hack" for me.
I honestly don't understand why Jamf didn't provide a solution for this.
For now the best solution I have heard is to put rosetta install script in prestage package
Posted on 12-17-2020 01:04 PM
Here is what I did...
I created an "empty" package with a preinstall script like this:
I tried running this on an M1 mac where Rosetta was not installed (just run manually from desktop). However, it complained:
However I googled for a while and found that I could expand InstallRosetta.pkg with:
pkgutil --expand "InstallRosetta.pkg" "InstallRosetta"
Then I used BBEdit to edit the file: InstallRosetta/Distribution and added: <options hostArchitectures="arm64,x86_64" />
Then I used command:
pkgutil --flatten "InstallRosetta" "InstallRosetta.pkg"
to put files back to a .pkg again.
Now when I ran the package again on the M1 mac, it didn't complain that Rosetta was missing and when it completed, it had actually installed Rosetta.
So I uploaded this package and added it to our prestage enrollment.
However it still doesn't work :(
I'm not sure why.
Posted on 08-18-2021 06:51 AM
Because you need rosetta on the machine to install pkg's
Posted on 12-17-2020 01:31 PM
@michael.madsen The why: pkgbuild on Big Sur creates packages that do NOT require rosetta.
pkgs build on Catalina (and older) DO require rosetta (on M1 macs)
This is independent on the content of the pkg....
see https://scriptingosx.com/2020/12/platform-support-in-macos-installer-packages-pkg/
Posted on 12-17-2020 01:50 PM
For anyone wanting to make this stateful without using an Extension Attribute, you can create a Smart Group based on "Packages Installed By Installer.app/SWU" "Has" "com.apple.pkg.RosettaUpdateAuto" and exclude your Rosetta policy from that.
Posted on 12-17-2020 02:34 PM
@michael.madsen curious how the proposed solution is a hack? i don't know where Jamf fits in resolving an issue that Apple should bake into their OS from the get go.
The problem with a pkg is that it either needs to be built in Big Sur or have some sort of plist/xml intended for the M1 architecture. but having script deploy through Jamf at enrollment is (or should be) a cleaner solution. In my instance I have DEPNotify deploy on enrollment complete for DEP and Manual enrollments, but I put the script as a Before in the same DEPNotify policy just to catch everything at once and it can kick off from there...having it separate may be a more appropriate choice but so far does not seem to be an issue as from the policy logs it appears to run as intended.
Posted on 12-17-2020 07:06 PM
@walt I use an enrollment policy which contains:
- Package (DEPNotify 1.1.6)
- Script (the script to make DEPNotify do it's thing)
However DEPNotify.app is not even downloaded to the machine if it's an M1 and Rosetta isn't installed.
I don't want to have to name my policies 0something or *something to make them run before other policies - of course this is a hack.
I want Rosetta to be installed in pre-staging
Posted on 12-17-2020 07:52 PM
@michael.madsen definitely file feedback with Apple as it should be installed natively with Big Sur at this point. You could also create a feature request with Jamf that perhaps Jamf deploys/checks for rosetta during DEP/ADE/other user enrollment.
I don't agree with the mentioned method being a hack, I mean look at Jamf in the big picture, everyone does things differently with their Jamf environment as its really choose your own adventure, I know there are feature requests to prioritize policies and other methods..so its definitely a method to accomplish what you want to do.
My suggestion is to simply create a new script with the above rtrouton script and add that to your DEPNotify policy as a Before script and it will run before the package is installed and should take care of the issue you are facing. since it's running purely as a script rather than a package (and similar to the separate policy that was recommended earlier, but my use case is its in a single policy).
Posted on 12-18-2020 04:42 AM
Has anyone tried enrolling an M1 mac Big Sur using enrollment quickadd.pkg? And then with enrollment the Rosatta install script gets kicked off?
Does the quickadd.pkg get stopped?
Posted on 12-18-2020 05:28 AM
@walt
Thank you, this (Add script to policy as "Before") actually worked.
I already sent feedback to Apple to make Rosetta installed by default. Maybe if enough of us do, they will pay attention :-)
Posted on 12-18-2020 05:36 AM
I use Ceremony soon to be Octory for my onboarding app, but I ran into the same problem. Rosetta2 not installed throwing an error when installing Ceremony. I made the script its own policy and run that prior to anything else, that way when/if apple decides to bake Rosetta in, I can simply retire the policy that installs it separately rather than re-packaging the Ceremony install. But as was stated, pick your own adventure. Cheers!
Posted on 01-06-2021 12:43 PM
@michael.madsen, I figured out the issue with the pre-stage enrollment if you are still interested in that scenario. The issue is in the package that you use. According to the documentation, the package has to be signed with the valid Apple Developer certificate - https://docs.jamf.com/10.9.0/jamf-pro/administrator-guide/Computer_PreStage_Enrollments.html
I signed the package using the productsign utility, and it works great. The Rosetta installation happens via pre-install script as part of the pre-stage enrollment package.
The downside is only in being an authorized Apple developer that will cost you $300 a year if you enroll for the Enterprise plan.
Posted on 01-19-2021 07:25 PM
Our approach to installing Rosetta 2 before the applications that need it:
That takes care of installing Rosetta 2 on ARM macs. Then for each Intel application X, create a smart group similar to above called "Needs Install: X" that finds computers without the application. Then configure a policy that installs X for members of that smart group, but add the "Needs Install: Rosetta 2" smart group to the exclusions list. That way, Intel and ARM macs share most of the configuration - it's just that ARM macs won't install X until Rosetta 2 has been installed.
I'm fairly new to Jamf so apologies if this is all obvious or misses the point.
Posted on 09-22-2021 01:55 PM
David, I think I'm doing the same thing as you but I can't get it to work. I have a smart group already created that will detect the M1 chip. In Composer I made a new install package that only has a preinstall script listed below. When I run the policy it shows that it installed but when I check the Mac it didn't. If I just run the the preinstall script locally it works.
I know I could just set this all up in the Policy itself but I need to have an installer package for our users that aren't in Jamf. What are your thoughts?
Posted on 01-20-2021 07:23 AM
@mwu1876 I have kept this policy with checked "Enrollment Complete" under general tab. And I have configured scope with SmartGroup Architecture Type arm64. So, once any M1 Mac gets enrolled, this policy will trigger immediately.
Posted on 01-20-2021 08:32 AM
@davidhogan It's been reported that installing a Big Sur update will remove any existing install of Rosetta. You may want to check and see if the com.apple.pkg.RosettaUpdateAuto
receipt is removed when that happens, otherwise you're going to get a false positive that Rosetta is installed.
Posted on 01-20-2021 04:28 PM
I also used the routon script. You create a policy, enrollment complete, in theory will run before the applications. I change after to before and set to once per computer. I see that some used ongoing. I had other issues when polices ran that way. But, Jamf also has a files and process payload and just execute /usr/sbin/softwareupdate --install-rosetta --agree-to-license... What's the difference? Files and process will give failed logs, because said machines were Intel based... Just wanted to throw that method as well. For me, I used the script this time, but usually use a Files and Process. Jamf installs it as root. Cheers
