DEPNotify GUI not starting
  • January 29, 2020
  • 6 replies
  • 49 views
Hi.
I am running into an issue that has become more prevalent with our DEPNotify workflow. Our enrollment policy is failing out when the DEPNotify-Starter script tries to open the app. It errors out with LSOpenURLsWithRole() failed for the application /Applications/Utilities/DEPNotify.app/Contents/MacOS/DEPNotify with error -54. I'm told its a permissions issue but I'm not sure with what. The app is installing to /Applications/Utilities as the script would expect and all the permissions are the same as when this actually worked. I've seen it happen on both Catalina and Mojave clients. The only way I actually get it to work is by manually clicking the DEPNotify app to launch it. Anyone else seen this? Oh I'm using DEPNotify 1.1.5 and DEPNotify-Starter 2.0.1 FYI
Best answer by ryan_ball
@sgorney This is the relevant code in the DEPNotify-Starter script:
sudo -u "$CURRENT_USER" open -a "$DEP_NOTIFY_APP" --args -path "$DEP_NOTIFY_LOG"
You might try this:
loggedInUID=$(/usr/bin/id -u "$CURRENT_USER")
/bin/launchctl asuser "$loggedInUID" /usr/bin/open -a "$DEP_NOTIFY_APP" --args -path "$DEP_NOTIFY_LOG"
  • January 29, 2020
Are you using a policy to kick off the script or is it copied local and executed with a LaunchAgent or something?
  • January 29, 2020
@tanderson Policy triggered by enrollment complete
Forum|alt.badge.img+19
  • January 30, 2020
You might try this:
  • February 11, 2020
There are a few areas with the above code. Should we replace all references of it?
  • April 16, 2020
I found three areas and replaced all three. The change worked for me. A million thanks!!!
  • September 16, 2020
Thanks. I assume leave the -jamf at the end of the string?
