Posted on
08-23-2023
05:49 AM
- last edited on
03-04-2025
08:15 AM
by
kh-richa_mig
We have a group of students that travel to external school. We have a Smart User group that shows all these students. I have scooped this smart user group to a profile to create a wifi on their device to connect to the external school's WIFI.(turning off private MAC as well)
I would like to send a list of the MAC addresses to the external school.
I can't figure out how to easily get a list of the devices and the WIFI MAC of those devices
Info
JAMF Pro 10.49
All devices are mobile devices iPads with latest iOS 16.5+
Total devices 2500+
Total users 3000+
Users in Smart users group to be targeted 30
Any ideas or information on how to tackle this would be appreciated.
-TechTroy
Posted on 08-23-2023 06:36 AM
You should be able to update what fields show when you export a report. Try going to Settings > Devices > Inventory Display and checking Wi-Fi MAC Address. Then export your group and see if the MAC Addresses are there. You could also make a Smart Search and check the box to display Wi-Fi MAC Address, and use that to export instead or view in the JAMF Console.
Posted on 08-23-2023 06:57 AM
I am looking to build a search for it. I can build a group with membership of a device group. I was thinking that I would just use the criteria that I would list any device that any member of the smart user group is a part of. But that is not even in the Advanced Criteria. You can pick from a smart mobile group but not a smart user group.
Posted on 08-23-2023 08:22 AM
Here is a round about way to do what I needed with a lot of manual work.
Since I created a profile that targeted the smart user group. I can see the profile and view the logs and get a list of Completed and pending. Since at our location each mobile device has a unique name (asset#) I can copy/paste the list to an external location (text editor)
I can create a Static device group which contains the devices that were targeted by the smart user group. Yes a lot of manual picking of 30 devices from the 2500+ devices list (search is helpful). Once I save the device group I can then save the list and print a report easily to gather the data easily. So I would have to go through this process every time classes changed or someone new joined or left.
I would like to have an option to create a search based on if the device belongs to one of the members of the Smart users group. Which would make this So much easier.
