Device was busy. Will try again
  • Sep 6, 2023 4:32 PM UTC
  • 11 replies
  • 2274 views
Doing testing in my office and pushing out several commands and profiles to a device. The device is connected to WIFI and has 5 bars signal strength. Everything works great until the screenlock kicks in, at which point, all progress comes to a complete halt. Any commands not executed going into pending with the status message "Device was busy. Will try again".
Seriously, if a device has a good WIFI signal and connection, we should be able to send updates to it. This is clearly related to the screenlock kicking in. Question is, why? Is there some helper service that stops responding if the screenlock is on? Or does the WIFI stop transferring data if the screenlock is on?
What if we tell our people to leave their devices plugged in over night to do a bunch of updates? Will they be pending all night long and then basically make the device useless in the morning when they unlock the screen and want to get to work?
  • Sep 6, 2023 4:40 PM UTC
To make matters worse, I just noticed that once the command goes pending with the "Device was busy. Will try again" status, even if I unlock the screen, nothing changes. For several minutes, the screenlock has been off and the WIFI is connected, but the command remains pending with the same message.
mvu
  • Sep 6, 2023 4:54 PM UTC
Try following up on all the commands you're pushing out with the Update Inventory MDM command. This seems to jiggle other commands to go through once the device is unlocked.
  • Sep 6, 2023 5:11 PM UTC
As soon as another command was sent to the device, all pending commands in the queue were executed so you were correct. But that is unacceptable behavior of the product. What if another command doesn't hit the device for hours?
Also, organizations have hundreds or thousands of devices and various states at the time of a remote command. They could be connected by WIFI and unlocked and probably okay. But others could be locked and either connected or not connected over WIFI, and the command would apparently remain in a pending status indefinitely until another command happens to kick the stuck command in the pants to get it going.
And considering the very high likelihood of a semi secure sceenlock policy of most enterprise devices, that would mean there's a good change that the vast majority of an organizations inventory has pending commands sitting there waiting for some external trigger to complete.
mvu
  • Sep 6, 2023 5:17 PM UTC
Yeah. I'm with you.
I don't know if this is an MDM or Apple Framework thing. Or both. Somebody smarter would have to chime in.
And there's no way we're sending an MDM command to clear passcodes so that MDM commands roll through.
  • Sep 6, 2023 5:35 PM UTC
Yeah. I'm with you.
Agreed, clearing passcodes is not an acceptable workaround. If this is something that can't be changed at the MDM level, the only thing I can think of is possibly creating a scheduled task that sends a blank push to all devices at a certain interval throughout the day. That way, if a device is unlocked and has pending commands, maybe that triggers their execution.
Ashok_A
  • Sep 10, 2023 8:55 AM UTC
@Lessardrp Remote commands depends on APNs even if your Network is stable. Check the Device APNs Connectivity: https://www.jamf.com/blog/test-connectivity-to-apple-push-notification-services/
Also, this could be because device is trying to complete an Remote Command and never ending which you can check from Activity Monitor app > network option. I would suggest to cancel all the Pending Commands from Jamf and send a blank push then check.
  • Sep 10, 2023 2:33 PM UTC
This can be the only command in the queue and it will still happen. And the connection can be fine. As soon as the screen lock kicks in I see the status go to "Device was busy. Will try again". Same connection, no other commands. The only difference is the screen lock is on.
JPSS
  • May 31, 2024 3:25 AM UTC
I don't know if you ever found a fix for this but we are in the same boat - 700 iPads and at any given time easily half of them are locked because they are not in use. I feel like this never used to happen to me, only time I would see a Device is Busy message was if the device was in first-time-setup, we have never noticed an issue where we couldn't check the inventory if the device was locked until maybe v11(?). It's a PITA and Jamf support are telling me it's expected behaviour and it was always that way.
And it's only inventory updates I'm seeing it with, other commands go through while the device is locked, I can turn off bluetooth for instance. and it will go through and leave the inventory update there because the Device Was Busy
  • Jan 26, 2025 6:22 PM UTC
Strongly suspect this is an Apple Device Management framework limitation.
https://developer.apple.com/documentation/devicemanagement/handling-notnow-status-responses?language=objc#Handle-NotNow-Responses
Can't confirm with any references, but I suspect that Jamf is intepreting a "NotNow" response from a device, and displaying "Device was busy" in the UI.
eric-p
  • Feb 11, 2025 9:21 PM UTC
I believe this is directly related to the original issue posted here. I'm seeing the same behavior on macOS where the computer has been rebooted but user has not logged in yet. I think a base interpretation of the issue is 'no commands processed while the volume is locked', whether it's due to screen lock or due to no user logged in. It appears that if the volume is locked, MDM commands will not process.
Answer from Copilot:
When FileVault is enabled and the screen is locked, it does impact remote access capabilities:
  1. MDM (Mobile Device Management): MDM can still manage the device, but certain actions that require the system to be unlocked (like installing software updates that need a restart) might be limited until the user logs in
    more or less confirms the behavior we've been seeing.
  • Apr 22, 2025 6:52 PM UTC
I don't know if this has been resolved but I've been seeing this issue and it is extremely annoying. I found that if I do a remote screen share, the act of authenticating for screen share will "wake up" the affected device and commands will execute.  You don't even need to complete the screen share connection.
You'd think it was the authentication BUT an ssh session does NOT trigger the "wake".
