Devices losing connection from Azure/Intune
  • June 18, 2020
  • 0 replies
  • 20 views
bwoods
Hello,
Since we began integrating our mac fleet with Azure/Intune, I've noticed that machines randomly fall out of compliance. Even if the Azure/Intune record says that the device is compliant. To fix this issue, my team usually has to completely remove the company portal, reinstall it, then re-enroll the device. Has anyone found a fix for this?
