Posted on
05-03-2017
07:58 AM
- last edited
3 weeks ago
by
kh-richa_mig
Hi everyone,
Our school wants to use 100-150 laptops for exams. In the past we've disabled and hidden Spotlight/notification center from the menu bar via script, but because of SIP we get errors until we disable it. Is there a way to completely disable this without having to boot to a recovery drive for each computer? Thanks!
Solved! Go to Solution.
Posted on 05-10-2017 02:38 PM
So just came up with a solution - deploy a com.apple.Spotlight.plist
file as a Custom Payload in a Configuration Profile.
Basically I just copied my ~/Library/Preferences/com.apple.Spotlight.plist
file and removed everything except the orderedItems
array. Just tested this at the computer-level and while it may not visually indicate being disabled in the Spotlight System Preferences pane, if you try and do a spotlight search nothing should appear.
One of the "gotchas" I found was on my test machine I didn't have Xcode installed, and apparently the Developer search item does not appear in the Spotlight list unless /Applications/Xcode.app exists (per https://www.howtogeek.com/231829/how-to-disable-developer-search-results-in-spotlight-on-a-mac/)
To get around this I just manually added the dictionary at the bottom of the list with the name SOURCE
. Now if Spotlight is invoked, nothing shows up.
<plist version="1.0">
<dict>
<key>orderedItems</key>
<array>
<dict>
<key>enabled</key>
<false/>
<key>name</key>
<string>APPLICATIONS</string>
</dict>
<dict>
<key>enabled</key>
<false/>
<key>name</key>
<string>MENU_SPOTLIGHT_SUGGESTIONS</string>
</dict>
<dict>
<key>enabled</key>
<false/>
<key>name</key>
<string>MENU_CONVERSION</string>
</dict>
<dict>
<key>enabled</key>
<false/>
<key>name</key>
<string>MENU_EXPRESSION</string>
</dict>
<dict>
<key>enabled</key>
<false/>
<key>name</key>
<string>MENU_DEFINITION</string>
</dict>
<dict>
<key>enabled</key>
<false/>
<key>name</key>
<string>SYSTEM_PREFS</string>
</dict>
<dict>
<key>enabled</key>
<false/>
<key>name</key>
<string>DOCUMENTS</string>
</dict>
<dict>
<key>enabled</key>
<false/>
<key>name</key>
<string>DIRECTORIES</string>
</dict>
<dict>
<key>enabled</key>
<false/>
<key>name</key>
<string>PRESENTATIONS</string>
</dict>
<dict>
<key>enabled</key>
<false/>
<key>name</key>
<string>SPREADSHEETS</string>
</dict>
<dict>
<key>enabled</key>
<false/>
<key>name</key>
<string>PDF</string>
</dict>
<dict>
<key>enabled</key>
<false/>
<key>name</key>
<string>MESSAGES</string>
</dict>
<dict>
<key>enabled</key>
<false/>
<key>name</key>
<string>CONTACT</string>
</dict>
<dict>
<key>enabled</key>
<false/>
<key>name</key>
<string>EVENT_TODO</string>
</dict>
<dict>
<key>enabled</key>
<false/>
<key>name</key>
<string>IMAGES</string>
</dict>
<dict>
<key>enabled</key>
<false/>
<key>name</key>
<string>BOOKMARKS</string>
</dict>
<dict>
<key>enabled</key>
<false/>
<key>name</key>
<string>MUSIC</string>
</dict>
<dict>
<key>enabled</key>
<false/>
<key>name</key>
<string>MOVIES</string>
</dict>
<dict>
<key>enabled</key>
<false/>
<key>name</key>
<string>FONTS</string>
</dict>
<dict>
<key>enabled</key>
<false/>
<key>name</key>
<string>MENU_OTHER</string>
</dict>
<dict>
<key>enabled</key>
<false/>
<key>name</key>
<string>MENU_WEBSEARCH</string>
</dict>
<dict>
<key>enabled</key>
<false/>
<key>name</key>
<string>SOURCE</string>
</dict>
</array>
</dict>
</plist>
Posted on 05-11-2017 07:37 AM
@aporlebeke this worked like a charm when I deployed it individually. I had to run a quick set of commands after that made it work:
sudo rm Library/Preferences/com.apple.Spotlight.plist
killall cfprefsd
Going to test this on a small scale deployment. I'll let everyone know how it works. Thanks!
Posted on 05-03-2017 08:07 AM
I opened a ticket with Apple on this in April, I wanted to do almost the same thing, disable the widgets and notifications, and the response was: Hi Don,
I completed testing and verified the results with several other engineers. We're not able to identify a method to disable widgets that does not require disabling SIP. I know this is not the result we'd hoped for, but the complexity of extensions prohibits a manual solution.
I'll continue to monitor the feature request and let you know as I receive additional information. Please let me know if you have any additional questions.
Thanks
Posted on 05-10-2017 02:05 PM
+1 for interest
<dict>
<array>
<dict>
<key>enabled</key>
<false/>
<key>name</key>
</dict>
<dict>
<key>enabled</key>
<false/>
<key>name</key>
</dict>
<dict>
<key>enabled</key>
<false/>
<key>name</key>
</dict>
<dict>
<key>enabled</key>
<false/>
<key>name</key>
</dict>
<dict>
<key>enabled</key>
<false/>
<key>name</key>
</dict>
<dict>
<key>enabled</key>
<false/>
<key>name</key>
</dict>
<dict>
<key>enabled</key>
<false/>
<key>name</key>
</dict>
<dict>
<key>enabled</key>
<false/>
<key>name</key>
</dict>
<dict>
<key>enabled</key>
<false/>
<key>name</key>
</dict>
<dict>
<key>enabled</key>
<false/>
<key>name</key>
</dict>
<dict>
<key>enabled</key>
<false/>
<key>name</key>
</dict>
<dict>
<key>enabled</key>
<false/>
<key>name</key>
</dict>
<dict>
<key>enabled</key>
<false/>
<key>name</key>
</dict>
<dict>
<key>enabled</key>
<false/>
<key>name</key>
</dict>
<dict>
<key>enabled</key>
<false/>
<key>name</key>
</dict>
<dict>
<key>enabled</key>
<false/>
<key>name</key>
</dict>
<dict>
<key>enabled</key>
<false/>
<key>name</key>
</dict>
<dict>
<key>enabled</key>
<false/>
<key>name</key>
</dict>
<dict>
<key>enabled</key>
<false/>
<key>name</key>
</dict>
<dict>
<key>enabled</key>
<false/>
<key>name</key>
</dict>
<dict>
<key>enabled</key>
<false/>
<key>name</key>
</dict>
<dict>
<key>enabled</key>
<false/>
<key>name</key>
</dict>
</array>
</dict>
</plist>
killall cfprefsd
