Has anyone else seen a problem when building DMG's on Leopard and installing them on Tiger?
I just built a dmg for Firefox 3.0.13 on Leopard and I noticed that I lost javascript functionality (toggling it on/off didn't help). I then built the dmg on a Tiger machine and I was once again able to use javascript. This was most notable on youtube.com where I knew Flash was working, and had to track down why JavaScript apparently wasn't running.
Composer 7.01 was used on both OS's to build the DMG's.
So far out of the several DMG's that I've built on Leopard based machines this is the first one that has caused any major problems, so I'll hopefully be able to dig into it deeper later when I have time.
Thanks,
Dave
David Lundgren
Sr. IT Systems Administrator
Brooks Institute - "Passion. Vision. Excellence."
27 East Cota Street
Santa Barbara, CA 93101
(805) 690-7615 (office)
(888) 304-3456 (toll-free)
http://www.brooks.edu
Be the first to reply!
