Hello JAMF Nation, I'm working on a new system image deployed by Casper . . . End user's will all be logging in using their Active Directory accounts.
One of the last tasks I have is to set a customized dock for all users when they log in. I've explored using dockutil (https://github.com/kcrawford/dockutil) for doing the actual modifications, which works great. the problem I'm having is how to trigger the dockutil policy so that each user gets the custom dock the first time the log into a given machine- i.e. if I've logged into mac123 before, the policy does not run, but if i've never logged into mac123 before, it does.
I'm trying to solve it this way since modifying the user template doesn't seem to work for AD account docks.
Any tips?
Dock config for AD users . . Is a manual trigger the solution?
Best answer by bentoms
AD account is created from the usual template. So FUT & FEU's should do what it normally does. :)
@Tom, we use this to set default dock (Finder, Safari, CS5 apps, sys prefs etc)...
Stops the calls when people contact IT as don't have an app installed. Only because they cannot see it in the Dock!!
You can use with MCX to add group folders etc... Also, this way the docks not locked, which can be handy.
