Dockutil not working with Mojave
  • January 26, 2020
  • 7 replies
  • 55 views
I use dockutil to set up the dock for each user on their Mac to have a few web browsers, Microsoft office and their home folders. It also removes stuff like FaceTime and messages and mail app. This works great on high Sierra but I’ve noticed if I upgrade a iMac to Mojave from high Sierra using normal Apple installer dockutil still works on Mojave but if I wipe the Mac and install Mojave fresh the dock util policy says it worked but the dock is just the standard Apple dock and still has face time and messages and doesn’t have my web browsers and Microsoft office. Any help much appreciated thanks
  • January 27, 2020
Edit:
On a iMac that had dockutil working in high sierra when I upgrade to Mojave it doesn't work and the dock gets the policy for the settings of the dock but keeps the standard apple settings.
adibue
  • January 27, 2020
Hey Joe
We successfully use Dockutil in our environment with Mojave and Catalina.
Below is an example of a Dockutil-Script that works perfectly fine for us under Mojave:
# This script creates a Dock using 'diskutil'
    currentuser=$(python -c 'from SystemConfiguration import SCDynamicStoreCopyConsoleUser; import sys; username = (SCDynamicStoreCopyConsoleUser(None, None, None) or [None])[0]; username = [username,""][username in [u"loginwindow", None, u""]]; sys.stdout.write(username + "
    dockutil="/usr/local/bin/dockutil"
    # Remove all
    su -l "${currentuser}" -c "${dockutil} --remove all --no-restart"
    sleep 5
    # Add applications
    su -l "${currentuser}" -c "${dockutil} --add '/Applications/Safari.app' --no-restart"
    su -l "${currentuser}" -c "${dockutil} --add '/Applications/Microsoft Word.app' --no-restart"
    su -l "${currentuser}" -c "${dockutil} --add '/Applications/Microsoft Excel.app' --no-restart"
    su -l "${currentuser}" -c "${dockutil} --add '/Applications/Microsoft PowerPoint.app' --no-restart"
    su -l "${currentuser}" -c "${dockutil} --add '/Applications/Microsoft Outlook.app' --no-restart"
    su -l "${currentuser}" -c "${dockutil} --add '/Applications/Cisco Jabber.app' --no-restart"
    su -l "${currentuser}" -c "${dockutil} --add '/Applications/Notes.app' --no-restart"
    su -l "${currentuser}" -c "${dockutil} --add '/Applications/System Preferences.app' --no-restart"
    su -l "${currentuser}" -c "${dockutil} --add '/Applications/Self Service' --no-restart"
    su -l "${currentuser}" -c "${dockutil} --add '/Applications/Utilities/Keychain Access.app' --no-restart"
    # Add folders
    su -l "${currentuser}" -c "${dockutil} --add '/Applications' --view grid --display folder --no-restart"
    su -l "${currentuser}" -c "${dockutil} --add '~/Downloads' --view grid --display folder --no-restart"
    # Kill dock
    su -l "${currentuser}" -c "killall Dock"
exit 0      ## Success
exit 1      ## Failure
  • January 27, 2020
We use dockutil too, mind the difference between 10.14 and 10.15 for system apps:
10.14: /Applications/System Preferences.app
10.15: /System/Applications/System Preferences.app
  • January 27, 2020
There's a few more:
Launchpad - file://Macintosh HD/System/Applications/Launchpad.app
Facetime - file://Macintosh HD/System/Applications/FaceTime.app
TV app is new. - file://Macintosh HD/System/Applications/Tv.app
Podcasts app is new. - file://Macintosh HD/System/Applications/Podcasts.app
Music app is new - file://Macintosh HD/System/Applications/Music.app
I'm probably missing a couple.
  • January 28, 2020
I have used Error Free IT/Dockmaster for a while now and it seems to work without any issues
https://github.com/Error-freeIT/Dock-Master
  • January 28, 2020
Here is my script that i used
https://github.com/TheNite/Jamf-Scripts/blob/master/dock.sh
# Configure the dock for a new user
# Script to to be use during the splash buddy setup on jamf
# This will also allow new hires to remove any of the default apps if they wish so.
# This script assumes the brew package "Dockutil" is installed as per the enrollment of the computer
# Run this Script with splashbuddy
# Arrays of Apps
# Apps that are installed in the '/Applications/' directory
Apps=("Firefox.app" "Slack.app" "Sublime Text.app" "1Password 7.app" "Messages.app" "Github Desktop.app" "PostMan.app" "xcode.app" "App store.app")
#Default systems that are installed in the '/Applications/Utitlies/' directory
system_utilities_apps=("Terminal.app")
#System defautl apps that are installed in the '/Applications/' OR for Catalina in '/System/Applications/' directory
system_default_apps=("System Preferences.app")
#Folders to add to the dock
user_folders=("Downloads")
# Variables
 macos_vers=$(sw_vers -productVersion | awk -F "." '{print $2}')
dockutil=/usr/local/bin/dockutil
sleepTime=2
#FolderLocations
appFolder="/Applications"
utilAppFolder="$appFolder/Utilities"
#Remove all current dock items
$dockutil --remove all --no-restart --allhomes
# Add apps to docks
function dockutil_catalina {
    for app in "${Apps[@]}"; do
        echo ${app}
        $dockutil --add "$appFolder/${app}" --no-restart --allhomes
    done
    for app in "${system_default_apps[@]}"; do
        echo ${app}
        $dockutil --add "/System/Applications/${app}" --no-restart --allhomes
    done
    for app in "${system_utilities_apps[@]}"; do
        echo ${app}
        $dockutil --add "/System/$utilAppFolder/${app}" --no-restart --allhomes
    done
    for folder in "${userFolders[@]}"; do
        $dockutil --add "~/${folder}" --no-restart --allhomes
    done
function dockutil_all() {
        echo ${app}
    done
        $dockutil --add "$utilAppFolder/${app}" --no-restart --allhomes
    done
    done
if [[ "$macos_vers" -ge 15 ]]; then
    dockutil_catalina
    dockutil_all
defaults write com.apple.dock show-recents -bool FALSE
# Cleanup
sleep $sleepTime
/usr/bin/killall Dock >/dev/null 2>&1
  • May 20, 2020
Hi. Can someone help me with modify a scrip for 10.15 to only include the following on the dock under a local administrator account:
Chrome, Terminal, Activity Monitor, Console, Disk Utility, Sublime Text, Batchmod, and settings
