Dropbox Smart Sync - Password Required?!
  • October 8, 2018
  • 2 views
We created a Dropbox package (using v58.4.92) via Composer. Everything goes well until a user signs into Dropbox and System password prompt appears for Smart Sync.
Is there a way to bypass this so end users do not need admin credentials to have the full functionality of the Dropbox app?
Thanks in advance!
1 reply
  • 1002 replies
  • October 9, 2018
Check and make sure it's not putting the sync folder in a location that requires admin rights to access, composer might do this if it was capturing any user settings.
Cookie policy
Cookie settings
