Error running script: return code was 2. while running script for ventura update
Please check and suggest.
getting the below error while running script for mac os ventura update
Install finished successfully Scanning for 13.0.1 installer Install finished successfully /Library/Application Support/JAMF/tmp/MacOSUpgrade.sh test 2: line 6: /Applications/Install macOS Ventura Beta.app.app/Contents/Resources/startosinstall: No such file or directory /Library/Application Support/JAMF/tmp/MacOSUpgrade.sh test 2: line 7: syntax error near unexpected token `|' /Library/Application Support/JAMF/tmp/MacOSUpgrade.sh test 2: line 7: `echo <password> |'/Applications/Install macOS Ventura Beta.app/Contents/Resources/startosinstall' --agreetolicense --nointeraction --forcequitapps --user <admin> --stdinpass'
Best answer by mickgrant
 you probably have an issue here as well
karthikeyan_mac
  • 281 replies
  • November 23, 2022
echo <password> |<space>'/Applications/Install macOS Ventura Beta.app/Contents/Resources/startosinstall'- try giving space after | in line 7.
Thanks.
  • 23 replies
  • November 23, 2022
Thanks.
Thanks, will try
mickgrant
  • 140 replies
  • November 23, 2022
  • 23 replies
  • December 6, 2022
thanks. Now i am getting the below error. unable to get authorize. even though entered admin user name password
Install finished successfully Error: failed to authorize for installation. Provide a password with --stdinpass or --passprompt. By using the agreetolicense option, you are agreeing that you have run this tool with the license only option and have read and agreed to the terms. If you do not agree, press CTRL-C and cancel this process immediately.
softwareupdate --list-full-installers | grep 'macOS' | awk '{print ++count " " $0}'
softwareupdate --fetch-full-installer
softwareupdate --fetch-full-installer --full-installer-version 13.0.1
echo $pass | '/Applications/Install macOS Ventura.app/Contents/Resources/startosinstall' --user $admin --stdinpass --agreetolicense --nointeraction --forcequitapps
Cookie policy
Cookie settings
