eSIM Smart Group?
  • January 14, 2025
  • 28 views
mvu
Forum|alt.badge.img+21
Can anybody share what smart group criteria you're using to see what mobile devices in the environment are using eSIM?
Or is eSIM compatible?
Shyamsundar
  • January 16, 2025
you can use this criteria Current Carrier Network to check the eSIM status
mvu
  • January 16, 2025
This field pulls in both physical SIM and eSIM data, so it's hard to tell which is which. Unless I'm missing something.
