Extension Attribute for Year of Mac without Model
  • July 14, 2020
  • 11 views
This script checks for if the Mac is an M1 Chip, then if it is not, will check for the OS. Depending on these conditions, the year will be read differently.
#!/bin/sh #Set variables for processor, apple chip, & operating system version
processor=$(/usr/sbin/sysctl -n machdep.cpu.brand_string )
AppleChip="Apple M1"
AppleChipYear=$(/usr/libexec/PlistBuddy -c "print :'CPU Names'" ~/Library/Preferences/com.apple.SystemProfiler.plist | tr ' ' ' ' | grep -e "M1, 20[0-9][0-9]" -e "20[0-9][0-9]" | sed 's/[[:punct:]]$//' )
os_ver=$(sw_vers -productVersion | awk -F. '{print $2}')
os_ver2=$(sw_vers -productVersion | awk -F. '{print $1}')
#check if the machine is an Apple M1 processor
if [[ "$processor" == *"$AppleChip"* ]]; then
echo "$AppleChipYear" else
#Check which operating system version is on the mac if not an Apple M1 chip processor
if [[ ${os_ver} -le 14 ]] && [[ ${os_ver2} -le 10 ]]; then plistFile="/System/Library/PrivateFrameworks/ServerInformation.framework/Versions/A/Resources/English.lproj/SIMachineAttributes.plist"
sysModel=$(sysctl hw.model | awk '{print $NF}')
modelYear=$(/usr/libexec/PlistBuddy -c "Print ${sysModel}:_LOCALIZABLE_:marketingModel" "$plistFile" | tr ' ' '\\n' | grep -o "20[0-9][0-9]") if [ ! -z "$modelYear" ]; then
echo "$modelYear"
echo "N/A"
elif [[ ${os_ver} -ge 15 ]]; then plistFile="/System/Library/PrivateFrameworks/ServerInformation.framework/Versions/A/Resources/en.lproj/SIMachineAttributes.plist"
sysModel=$(sysctl hw.model | awk '{print $NF}') modelYear=$(/usr/libexec/PlistBuddy -c "Print ${sysModel}:_LOCALIZABLE_:marketingModel" "$plistFile" | tr ' ' '\\n' | grep -o "20[0-9][0-9]") if [ ! -z "$modelYear" ]; then
echo "$modelYear"
echo "N/A"
elif [[ ${os_ver} -le 14 ]] && [[ ${os_ver2} -ge 11 ]]; then
modelYear=$(/usr/libexec/PlistBuddy -c "Print ${sysModel}:_LOCALIZABLE_:marketingModel" "$plistFile" | tr ' ' ' ' | grep -e "M1, 20[0-9][0-9]" -e "20[0-9][0-9]" | sed 's/[[:punct:]]$//')
echo "$modelYear"
echo "N/A"
#end
  • September 23, 2021
@Steven5342 Can you post all script here with the update, thanks.
  • September 30, 2021
@jamflund I edited the post and the script should work now for all Mac computers.
mani2care
  • December 27, 2022
Hi All i tried this script its not working at all M1 and intel both are having error any latest version script any one having it supported for all the mac devices
