Falcon repair script
  • January 23, 2025
  • 178 views
Greetings Jamf Nation!
I have been woking on a more comprehensive Falcon repair script to assist in detecting and/or trying to repair any potential issues found in the sensors.  This is strictly a WIP and I would love to get everyone's feedback on ideas or items that I might have missed.  This script is borrowing heavily from Dan K Snelson, so kudos for him creating the original concept...I just want to take it a "one step further"...
#!/bin/zsh # # Written by: Scott Kendall # Date Created: 01/21/2025 # Date Last Revised: 01/23/2025 # # Borrowed heavily from @snelson: source code @ https://snelson.us/2023/03/crowdstrike-falcon-kickstart-0-0-2/ # ###################################################################################################### # # Gobal "Common" variables (do not change these!) # ###################################################################################################### export PATH=/usr/bin:/usr/local/bin:/bin:/usr/sbin:/sbin SUPPORT_DIR="<your support log folder>" LOG_DIR="${SUPPORT_DIR}/logs" LOG_FILE="${LOG_DIR}/FalcanSensor.log" LOG_STAMP=$(echo $(/bin/date +%Y%m%d)) falconBinary="/Applications/Falcon.app/Contents/Resources/falconctl" falcanJAMFtrigger="crowdstrike" exitCode="0" #################################################################################################### # # Functions # #################################################################################################### function create_log_directory () { # Ensure that the log directory and the log files exist. If they # do not then create them and set the permissions. # # RETURN: None # If the log directory doesnt exist - create it and set the permissions [[ ! -d "${LOG_DIR}" ]] && /bin/mkdir -p "${LOG_DIR}" /bin/chmod 755 "${LOG_DIR}" # If the log file does not exist - create it and set the permissions [[ ! -f "${LOG_FILE}" ]] && /usr/bin/touch "${LOG_FILE}" /bin/chmod 644 "${LOG_FILE}" } function logMe () { # Basic two pronged logging function that will log like this: # # 20231204 12:00:00: Some message here # # This function logs both to STDOUT/STDERR and a file # The log file is set by the $LOG_FILE variable. # # RETURN: None echo "${1}" 1>&2 echo "$(/bin/date '+%Y-%m-%d %H:%M:%S'): ${1}" | tee -a "${LOG_FILE}" } function preflight_check () { # Pre-flight Check: Confirm script is running as root [[ $(id -u) -ne 0 ]] && {logMe "PRE-FLIGHT CHECK: This script must be run as root; exiting."; exit 1} # Pre-flight Check: Confirm CrowdStrike Falcon System Extension is running systemExtensionTest=$( systemextensionsctl list | grep -o "com.crowdstrike.falcon.Agent.*" | cut -f2- -d" " ) if [[ -n "${systemExtensionTest}" ]]; then systemExtensionStatus="${systemExtensionTest}" else systemExtensionStatus="Not Found" logMe "Falcon not installed: Loading policy from JAMF" fi logMe "CrowdStrike Falcon System Extension Status: ${systemExtensionStatus}" ################################################### # Pre-flight Check: Complete ################################################### logMe "PRE-FLIGHT CHECK: Complete" } function log_sensor_updates() { logMe "Falcon Sensor Operational: ${1}" logMe "Updating inventory …" jamf recon } function connection_test() { test=$("nc -vz ts01-b.cloudsink.net 443") [["${test}" == *"succedded!"* ]] && echo "true" || echo "false" } function load_sensor() { echo $( ${falconBinary} load --verbose) } function load_jamf_policy () { jamf policy -trigger "${falcanJAMFtrigger}" } function get_agent_info () { echo $( $falconBinary stats agent_info 2>&1 ) } #################################################################################################### # # Program # #################################################################################################### create_log_directory preflight_check exitCode="0" ################################################### # Process CrowdStrike Falcon System Extension Status ################################################### logMe "Processing System Extension Status …" systemExtensionStatus=$(systemextensionsctl list | grep -o "com.crowdstrike.falcon.Agent.*" | cut -f2- -d" ") # Check the extension status first and evaluate case ${systemExtensionStatus} in *"[activated enabled]"* ) logMe "CrowdStrike Falcon System Extension enabled" logMe "Validating Sensor Operation …" sensorOperationalStatus=$( get_agent_info ) #| awk '/Sensor operational:/{print $3}') # check for specific issues in regards to the status case ${sensorOperationalStatus:l} in *"true"* ) # sensors are loaded and functioning correclty log_sensor_updates "${sensorOperationalStatus}" ;; *"sensor has not loaded."* | *"sensor is unknown."* | *"sensor is unloaded."* ) # Sensors are not loaded properly sensorOperationalStatus=$( load_sensor) logMe "Attempting to Load the Falcon Sensor" log_sensor_updates "${sensorOperationalStatus}" ;; *"not licensed"* ) # product is not licensed...perform a license command and then make sure that the sensors are loaded logMe "Attempting to License the Falcon Sensor" falconKickStartLicense=$( $falconBinary license "$( defaults read /Library/Managed\\ Preferences/com.crowdstrike.falcon.plist ccid )" --noload --verbose) log_sensor_updates "${falconKickStartLicense}" logMe "Attempting to Load the Falcon Sensor" sensorOperationalStatus=$( load_sensor) log_sensor_updates "${sensorOperationalStatus}" ;; esac ;; *"uninstall on reboot"* ) # It looks like a restart might be in order logMe "The system needs to be restarted for the sensor to load properly" exitCode="1" ;; *"waiting for user"* ) # it appears that everything is working OK, but the user needs to start doing "something" logMe "Falcon Sensor Status: ${sensorOperationalStatus}" ;; "Not Found" ) # Crowdstrike not found, so lets try to remove any previous install and try to reinstall it logMe "CrowdStrike Falcon System Extension NOT found: Attempting Re-installation" falconKickStartUninstall=$( ${falconBinary} uninstall -verbose ) log_sensor_updates "${falconKickStartUninstall}" logMe "Re-installing CrowdStrike Falcon …" load_jamf_policy exitCode="1" ;; * ) # Catch all if we got a different error logMe "Attempting to kickstart Falcon Sensor …" falconKickStartLicense=$( ${falconBinary} license ) logMe "Falcon Kickstart License Result: ${falconKickStartLicense}" falconKickStartLoad=$( load_sensor ) logMe "Falcon Kickstart Load Result: ${falconKickStartLoad}" if [[ "${falconKickStartLoad}" == "Falcon sensor is loaded" ]]; then sensorOperationalStatus=$( get_agent_info ) [[ "${sensorOperationalStatus}" == "true" ]] && logMe "Falcon Sensor Status: ${sensorOperationalStatus}" else exitCode="1" fi esac logMe "Exit Code: ${exitCode}" exit "${exitCode}"
mattjerome
  • January 23, 2025
I used to do something similar where I had an extension attribute that reported an error and if there was an error it went to a smart group that triggered a policy to uninstall and reinstall. That fixed 90% of issues.
sdagley
  • January 24, 2025
Anyone looking to deploy, and or remove/remediate, CrowdStrike on Macs should really do themselves a favor and look at @franton's guide on scripting that process with the CS API :
https://richard-purves.com/2022/05/03/downloading-crowdstrike-via-api-for-fun-and-profit/
And the associated GitHub repo:
https://github.com/franton/Crowdstrike-API-Scripts?tab=readme-ov-file
