Falcon Sensor Licensing Issue
  • April 13, 2023
  • 79 views
I was able to do the pre-requisite for Falcon, The install appears to be fine however the script to license doesn't appear to be working and i know why i use a script from the older version and i guess the structure has changed does anyone have the license script for falcon
Here is the log details
Script result:
Executing Policy Install CrowdStike Falcon Sensor
Downloading FalconSensorMacOS.MaverickGyr.pkg...
Downloading https://use1-jcds.services.jamfcloud.com//download/0e4976be1fe242abb3ce80e8556253bd/FalconSensorMacOS.MaverickGyr.pkg?token=cdf519ed75c141bea4937d44500440715ar4dxxmrcbdr8m9y5e95veg10tvlnij...
Verifying package integrity...
Installing FalconSensorMacOS.MaverickGyr.pkg...
Successfully installed FalconSensorMacOS.MaverickGyr.pkg.
Running script License Falcon...
Script exit code: 0
Script result: /Library/Application Support/JAMF/tmp/License Falcon: line 2: /Library/CS/falconctl: No such file or directory
Best answer by RenAdmin
This is the script that needs to be setup ti license if anyone needs it. was able to apply and verify it works.
sudo /Applications/Falcon.app/Contents/Resources/falconctl license XXXXXXXXXXX-XXXXX
1 reply
  • April 13, 2023
