Filevault 2 Reissue Problem
  • October 3, 2018
  • 42 views
I'm using the script below to reissue Filevault keys for newly enrolled users who already have Filevault2 turned on. Users get prompted to enter their password if they run the policy from the Self Service app and the key reissues with no problem. However, when the policy runs during a recurring checkin, it shows it's completed but they never receive a pop up. The error I see in the log is "No user interaction allowed (error attached). Anyone know what might be going on here?
# Copyright (c) 2017, JAMF Software, LLC.  All rights reserved.
#       Redistribution and use in source and binary forms, with or without
#       modification, are permitted provided that the following conditions are met:
#               * Redistributions of source code must retain the above copyright
#                 notice, this list of conditions and the following disclaimer.
#               * Redistributions in binary form must reproduce the above copyright
#                 notice, this list of conditions and the following disclaimer in the
#                 documentation and/or other materials provided with the distribution.
#               * Neither the name of the JAMF Software, LLC nor the
#                 names of its contributors may be used to endorse or promote products
#                 derived from this software without specific prior written permission.
#       THIS SOFTWARE IS PROVIDED BY JAMF SOFTWARE, LLC "AS IS" AND ANY
#       EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED
#       WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE
#       DISCLAIMED. IN NO EVENT SHALL JAMF SOFTWARE, LLC BE LIABLE FOR ANY
#       DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES
#       (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES;
#       LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND
#       ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT
#       (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF THIS
#       SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
# Description
# The purpose of this script is to allow a new individual recovery key to be issued
# if the current key is invalid and the management account is not enabled for FV2,
# or if the machine was encrypted outside of the JSS.
# First put a configuration profile for FV2 recovery key redirection in place.
# Ensure keys are being redirected to your JSS.
# This script will prompt the user for their password so a new FV2 individual
# recovery key can be issued and redirected to the JSS.
# HISTORY
# -Created by Sam Fortuna on Sept. 5, 2014
# -Updated by Sam Fortuna on Nov. 18, 2014
# -Added support for 10.10
#   -Updated by Sam Fortuna on June 23, 2015
#       -Properly escapes special characters in user passwords
# -Updated by Bram Cohen on May 27, 2016
# -Pipe FV key and password to /dev/null
# -Updated by Jordan Wisniewski on Dec 5, 2016
# -Removed quotes for 'send {${userPass}}           ' so
# passwords with spaces work.
# -Updated by Shane Brown/Kylie Bareis on Aug 29, 2017
# - Fixed an issue with usernames that contain
# sub-string matches of each other.
# -Updated by Bram Cohen on Jan 3, 2018
# - 10.13 adds a new prompt for username before password in changerecovery
# -Updated by Matt Boyle on July 6, 2018
# - Error handeling, custom Window Lables, Messages and FV2 Icon
# -Updated by David Raabe on July 26, 2018
# - Added Custom Branding to pop up windows
# Parameter 4 = Set organization name in pop up window
# Parameter 5 = Failed Attempts until Stop
# Parameter 6 = Custom text for contact information.
# Parameter 7 = Custom Branding - Defaults to Self Service Icon
#Customizing Window
selfServiceBrandIcon="/Users/$3/Library/Application Support/com.jamfsoftware.selfservice.mac/Documents/Images/brandingimage.png"
jamfBrandIcon="/Library/Application Support/JAMF/Jamf.app/Contents/Resources/AppIcon.icns"
fileVaultIcon="/System/Library/CoreServices/CoreTypes.bundle/Contents/Resources/FileVaultIcon.icns"
if [ ! -z "$4" ]
then
orgName="$4 -"
if [ ! -z "$6" ]
then
haltMsg="$6"
haltMsg="Please Contact IT for Further assistance."
if [[ ! -z "$7" ]]; then
brandIcon="$7"
elif [[ -f $selfServiceBrandIcon ]]; then
  brandIcon=$selfServiceBrandIcon
elif [[ -f $jamfBrandIcon ]]; then
  brandIcon=$jamfBrandIcon
brandIcon=$fileVaultIcon
## Get the logged in user's name
userName=$(/usr/bin/stat -f%Su /dev/console)
## Grab the UUID of the User
userNameUUID=$(dscl . -read /Users/$userName/ GeneratedUID | awk '{print $2}')
## Get the OS version
OS=`/usr/bin/sw_vers -productVersion | awk -F. {'print $2'}`
## This first user check sees if the logged in account is already authorized with FileVault 2
userCheck=`fdesetup list | awk -v usrN="$userNameUUID" -F, 'match($0, usrN) {print $1}'`
if [ "${userCheck}" != "${userName}" ]; then
echo "This user is not a FileVault 2 enabled user."
exit 3
## Counter for Attempts
try=0
if [ ! -z "$5" ]
then
maxTry=$5
maxTry=2
## Check to see if the encryption process is complete
encryptCheck=`fdesetup status`
statusCheck=$(echo "${encryptCheck}" | grep "FileVault is On.")
expectedStatus="FileVault is On."
if [ "${statusCheck}" != "${expectedStatus}" ]; then
echo "The encryption process has not completed."
exit 4
passwordPrompt () {
## Get the logged in user's password via a prompt
echo "Prompting ${userName} for their login password."
userPass=$(/usr/bin/osascript -e "
on run
display dialog "To generate a new FileVault key" & return & "Enter login password for '$userName'" default answer "" with title "$orgName FileVault Key Reset" buttons {"Cancel", "Ok"} default button 2 with icon POSIX file "$brandIcon" with text and hidden answer
set userPass to text returned of the result
return userPass
end run")
if [ "$?" == "1" ]
then
echo "User Canceled"
try=$((try+1))
if [[ $OS -ge 9 ]] &&  [[ $OS -lt 13 ]]; then
## This "expect" block will populate answers for the fdesetup prompts that normally occur while hiding them from output
result=$(expect -c "
log_user 0
spawn fdesetup changerecovery -personal
expect "Enter a password for '/', or the recovery key:"
send {${userPass}}
send
log_user 1
expect eof
" >> /dev/null)
elif [[ $OS -ge 13 ]]; then
log_user 0
expect "Enter the user name:"
send {${userName}}
send
send {${userPass}}
send
log_user 1
expect eof
echo "OS version not 10.9+ or OS version unrecognized"
echo "$(/usr/bin/sw_vers -productVersion)"
exit 5
successAlert () {
on run
display dialog "" & return & "Your FileVault Key was successfully Changed" with title "$orgName FileVault Key Reset" buttons {"Close"} default button 1 with icon POSIX file "$brandIcon"
end run"
errorAlert () {
on run
display dialog "FileVault Key not Changed" & return & "$result" buttons {"Cancel", "Try Again"} default button 2 with title "$orgName FileVault Key Reset" with icon POSIX file "$brandIcon"
end run"
 if [ "$?" == "1" ]
  then
try=$(($try+1))
haltAlert () {
on run
display dialog "FileVault Key not changed" & return & "$haltMsg" buttons {"Close"} default button 1 with title "$orgName FileVault Key Reset" with icon POSIX file "$brandIcon"
end run
while true
do
passwordPrompt
if [[ $result = *"Error"* ]]
then
echo "Error Changing Key"
if [ $try -ge $maxTry ]
then
haltAlert
echo "Quitting.. Too Many failures"
echo $result
errorAlert
echo "Successfully Changed FV2 Key"
successAlert
done
sdagley
  • October 3, 2018
@alex.cisneros If you edit your post and add a triple back-tick (```) before and after your script it'll properly display as code.
  • October 3, 2018
Thanks @sdagley Updated!
  • October 3, 2018
@alex.cisneros try wrapping in a Tell block instead.. userPass="$(/usr/bin/osascript -e 'Tell application "System Events" to display dialog..
