Has anybody been using Filevault 2 on a system with multiple partitions and one of those being mounted at /Users?
if so are you actually encrypting /Users and getting it to automount?
I thought at one point FV2 was going to be Whole Disk Encryption, but it is not, it only encrypts your root/boot volume and leaves your data unencrypted on the other partition.
So far in limited testing, when i encrypt the /Users partition it no longer mounts with the fstab entry, which is likely due to not having the passphrase to decrypt the disk.
anyhow if anybody has figured this out I would love to hear it.
FileVault 2 with UserData /Users on a separate parttiion
Best answer by nessts
Nice Crhis, thanks.
