FileVault2 Policy Jamf Pro
  • January 25, 2023
  • 33 views
brizkallah
good day.
after applying the Policy to enable the FV2 in JAMF, when the user restarts the machine he still have to
1- login to decrypt the disk
2- sign in again with the AD user name and password.
can someone offer a solution to have the password registered?
well, let me break it down in other words.
1- the devices/laptops are connected to the AD.
2- users always use there AD credentials to login.
3- the user now login twice, first login is to decrypt the disk and the second one is to login to the device itself.
4- so the problem is what if the user forgets his AD password and i did a reset on the AD, he will not be able to decrypt the disk in order to login.
so my question is that if i can just bypass the 1st login requested to decrypt the disk or i should be switching to a different method of enabling the FV2.
Best answer by AJPinto
The 1st problem is domain binding, stop that.
If a user forgets their password you should use the FV recovery key which will trigger a password reset. With domain binding this causes a problem.
AJPinto
  • January 25, 2023
brizkallah
  • January 25, 2023
well, if this is the case do you have a reliable documentations for it? or a test process that can be applied on a test machine? thank you for the help
