Flash 26.0.0.137 Patch Reporting
nvandam
Contributor II
Flash 26.0.0.137 came out yesterday. How long does it generally take before patches are updated in the Patch Reporting in JAMF Pro? 3b958bd6cad04d889f906f3bff0df750
1 ACCEPTED SOLUTION
robinsonjo
Contributor
Contributor
Hello @nvandam ,
Thanks for the inquiry! Our goal is to release patches within 48 hours of the software vendor's release of the version.
Flash specifically will be released shortly.
Thank you!
Jonny
1 REPLY 1
robinsonjo
Contributor
Contributor
Hello @nvandam ,
Thank you!
Jonny
