forticlient patch management through jamf patch management catalogue
  • April 13, 2022
  • 0 replies
  • 1 view
Has anybody played with pushing forticlient updates using the JAMF patch catalogue?
I tried to set it up on a lab machine. It correctly recognizes that forticlient has an upgrade available and notifies the user. If you select upgrade, it gives you the spinning wheel, but doesn't appear to upgrade the version of forticlient.
Anybody else try this?
