HELP!!!Multiple Managed Preferences - MCX Settings
  • January 12, 2012
  • 16 views
Hi jAMF NATION,
I don't know how many MCX settings you can apply before the machine starts slowing down. But I believe we should keep it simple and less.
I only applied two settings from JSS in my test environment and it already started playing up.
I used two settings to turn off BlueTooth and Airport for iMacs. First thing I notice is that the Airport shows as "not configured". So I guess the setting worked. Then the BlueTooth shows still on and I can click it to turn off and on, which looks like the BlueTooth MCX settings didn't come down. Restarted the computers a few times, same. Then I decided to turn Airport back on by setting the "Disable Airport" MCX to false and apply it. I can't even turn the Airport back on. Now all my iMacs shows Airport "Not Configured".
Has anyone had similar issues?
Any response is welcome!!!
Thank you.
donmontalvo
Forum|alt.badge.img+36
  • January 12, 2012
Is JSS's MCX removing AirPort from the list of network interfaces?
Don
Forum|alt.badge.img+31
  • January 12, 2012
So you want bluetooth and airport to completely be disabled?
  • January 12, 2012
Yes, I would like to turn both Bluetooth and Airport off on the iMac. Only Airport shows "Not Configured" and Bluetooth is still on. I also have trouble turning the Airport back on by setting the "Disable Airport" MCX to false.
