Help with configuration profile for GlobalProtect
jhuls
Contributor III
I'm attempting to create a configuration profile for GlobalProtect so that users don't have to enter the vpn server address. When testing the following which was added to a configuration profile in Jamf, it still prompts. Any ideas?
And, yes, I have our real address in the one I'm using.
<plist version="1.0">
<dict>
    <key>Palo Alto Networks</key>
    <dict>
        <key>GlobalProtect</key>
        <dict>
            <key>PanSetup</key>
            <dict>
                <key>Portal</key>
                <string>vpn.server.edu</string>
                <key>Prelogon</key>
                <string>0</string>
            </dict>
        </dict>
    </dict>
</dict>
</plist>
70 REPLIES 70
JG3741
New Contributor III
Hello,
I use a script to accomplish this, please edit the portal address and the script will take care of the rest.
# Set the portal address for GlobalProtect
portalAddress="LINKGOESHERE"
# Modify PLIST to reflect the correct portal address.
echo '<?xml version="1.0" encoding="UTF-8"?><!DOCTYPE plist PUBLIC "-//Apple//DTD PLIST 1.0//EN" "http://www.apple.com/DTDs/PropertyList-1.0.dtd"><plist version="1.0"><dict><key>Palo Alto Networks</key><dict><key>GlobalProtect</key><dict><key>PanSetup</key><dict><key>Portal</key><string>'$portalAddress'</string><key>Prelogon</key><integer>0</integer></dict></dict></dict></dict></plist>' >> /Library/Preferences/com.paloaltonetworks.GlobalProtect.settings.plist
macmanmk
Contributor
This is what we use for our config profile. Granted, we have two separate portals, so we use an array.
<dict>
    <key>PanPortalList</key>
    <array>
        <string>vpn1.server.com</string>
        <string>vpn2.server.com</string>
    </array>
</dict>
</plist>
cbd4s
Contributor II
In our deployment, we pushed out /Library/Preferences/com.paloaltonetworks.GlobalProtect.settings.plist which contains portal address. However, we also needed to remove user config files in all existing user home folders:
 rm -rf /Users/*/Library/Application Support/PaloAltoNetworks/GlobalProtect
 rm -rf /Users/*/Library/Preferences/com.paloaltonetworks.GlobalProtect*
 rm -rf /Users/*/Library/Preferences/PanGPS*
Otherwise the user config files seem to override the system library file.
Uninstalling GlobalProtect only removes the config files in current console user profile folder.
jason_bracy
Contributor III
So, what I did was upload a working plist file to a Computer level Configuration Profile with the "Preference Domain": com.paloaltonetworks.GlobalProtect
I have recently found that switching to a different portal (we have several VPNs for different users) will not take the new domain without doing a complete uninstall and reinstall. I found these instructions on the PaloAlto site.:
  1. Uninstall the GlobalProtect App for Mac.
  2. Determine if the GlobalProtect enforcer kernel extension exists on the endpoint. • On the Mac endpoint, open the Terminal application under the Applications/Utilities folder, and then enter the following command: • kextstat | grep gplock
  3. If the extension exists, unload the enforcer. • Enter the following command on the Terminal application to unload the enforcer: • sudo kextunload -b com.paloaltonetworks.GlobalProtect.gplock
  4. Prevent the enforcer from reloading after a reboot. • Enter the following command on the Terminal application to remove the enforcer from the Mac hard disk: • sudo rm -r "/System/Library/Extensions/gplock*.kext"
  5. Download and Install the GlobalProtect App for Mac.
So I have a GP remove policy that runs the following script and then calls the Global Protect installer once the new Profile is installed:
/Applications/GlobalProtect.app/Contents/Resources/uninstall_gp.sh
# Pre Catalina
rm -r /System/Library/Extensions/gplock*.kext
# Catalina
rm -r /Library/Extensions/gplock*.kext
rm /Library/Preferences/com.paloaltonetworks.GlobalProtect.plist
for USER in $(ls -ld /Users/* | grep ^d | grep -v "Shared" | awk {'print $NF'})
    do
        rm "$USER"/Library/Application Support/PaloAltoNetworks/GlobalProtect
        rm "$USER"/Library/Preferences/com.paloaltonetworks.GlobalProtect*
        rm "$USER"/Library/Preferences/PanGPS*
    done
killall cfprefsd
dan-snelson
Valued Contributor II
@jason.bracy Would you be willing to share the XML of the plist you're deploying? In limited testing, my custom Configuration Profile conflicted with settings GlobalProtect configured after initial setup.
My current approach is to use the following in our install policy, Files and Processes > Execute Command > …
/usr/libexec/PlistBuddy -c "Add :Palo Alto Networks:GlobalProtect:PanSetup:Portal string YOUR.FQDN.GOES.HERE" /Library/Preferences/com.paloaltonetworks.GlobalProtect.settings.plist ; /usr/bin/su - "`/usr/bin/stat -f%Su /dev/console`" -c "/usr/bin/pkill -l -U `/usr/bin/stat -f%Su /dev/console` GlobalProtect" ; /bin/sleep 3 ; /usr/local/bin/jamf recon
Dan
jason_bracy
Contributor III
@dan-snelson The plist uploaded to the configuration profile is very simple, the Domain that I am using is in the Profile is: com.paloaltonetworks.GlobalProtect and then I uploaded the following XML
<?xml version="1.0" encoding="UTF-8"?> <!DOCTYPE plist PUBLIC "-//Apple//DTD PLIST 1.0//EN" "http://www.apple.com/DTDs/PropertyList-1.0.dtd"> <plist version="1.0"> <dict> <key>Portal</key> <string>xxx.xxxx.xxx</string> </dict> </plist>
-portal address scrubbed to protect my network :-)
dan-snelson
Thanks, @jason.bracy … I had w-a-y more keys in mine.
Dan
jason_bracy
Contributor III
@dan-snelson looks like you were also using the domain "com.paloaltonetworks.GlobalProtect.settings" not "com.paloaltonetworks.GlobalProtect". In my testing using that did not work. Deleting all GP settings files (previous comment) and using the Configuration Profile with the the com.paloaltonetworks.GlobalProtect domain and the single portal key has been very solid and will then create the com.paloaltonetworks.GlobalProtect.settings file with the config that it gets from the server.
defaults read com.paloaltonetworks.GlobalProtect.settings { "Palo Alto Networks" = { GlobalProtect = { PanMSAgent = { "Client.DebugLevel" = 5; PanGPS = 5; SearchOrder = 1; "Service.DebugLevel" = 5; }; Settings = { ConfFromPortal = 7212; Configurations = 154; Configurations2 = 79; DisallowLocalAccess = 0; DisplayTrafficBlockingMsg = 1; DisplayWelcome = 1; HipCheckInterval = 0; LastUrl = "xxx.xxxx.xxx"; LocalSSLEnabled = 0; OtherDisableStarted = 0; OverrideMethod = allowed; UserOverrides = 3; "agent-user-override-timeout" = 0; "mfa-prompt-suppress-time" = 0; "ssl-only-selection" = 0; }; "Settings\xxx.xxxx.xxx" = { AuthTypes = 32; ConfFromPortal = 7212; Configurations = 154; Configurations2 = 79; DisplayTrafficBlockingMsg = 1; DisplayWelcome = 1; HipCheckInterval = 0; LocalSSLEnabled = 0; OtherDisableStarted = 0; OverrideMethod = allowed; UserOverrides = 3; "agent-user-override-timeout" = 0; "mfa-prompt-suppress-time" = 0; }; }; }; }
franton
Valued Contributor III
I've just gone through all of this. Palo Alto has changed the preference file, domain and format.
So for client version 5.0.4:
Domain: com.paloaltonetworks.GlobalProtect
<dict>
    <dict>
        <dict>
            <key>PanGPS</key>
            <dict>
                <key>UserProfileType</key>
            </dict>
            <key>Settings</key>
            <dict>
                <key>connect-method</key>
                <string>on-demand</string>
                <key>disable-globalprotect</key>
                <integer>1</integer>
                <key>prelogon</key>
                <key>regioncode</key>
                <string>US</string>
            </dict>
        </dict>
    </dict>
    <array>
        <string>vpn.corp.com</string>
    </array>
</dict>
</plist>
For client version 5.1.3-12
Domain: com.paloaltonetworks.GlobalProtect.client
<dict>
    <array>
    </array>
    <key>User</key>
    <string></string>
</dict>
</plist>
I hope that helps. I'm deploying both right now just to cope. I really wish devs wouldn't do this.
sdagley
Esteemed Contributor
@franton Thanks for the heads up on this. Developers should be required to do IT support for their product and see first hand how much people appreciate such major structural changes in minor version updates.
franton
@sdagley This kind of arbitrary change from Vendor's really annoys me. It's caused no end of bother in my org.
dan-snelson
Thanks, @franton; worked like a champ.
Dan
captam3rica
New Contributor III
@franton are these profiles being deployed as custom configuration profiles in Jamf. If so, are they set at the computer level or user level? Or, are the profiles deployed manually through a package or other means?
joeyk
New Contributor II
I'm also curious the best way to get this into the user's ~/Library/Preferences - I have tried "write defaults" as a script but can't get it to write it to the local user.
TIA
franton
@captam3rica I'm deploying as computer level for everything.
tep
Contributor II
When I use @franton's profile, my GP hangs at "Connecting..." indefinitely. As soon as I unscope the profile, GP prompts for the portal and can connect. This is GP 5.1.5 - upgrading from 5.0.3.
franton
@tep had issues with that. found that one of the background processes can get stuck, but force killing them and effectively restarting the client helps. Our situation is mostly caused by our SAML based login.
elsmith
New Contributor III
@franton Do you have an example of a plist for 5.1.3-12 that also includes the
<key>connect-method</key> <string>on-demand</string>
portion? No matter what I try on that, I cannot get it to work. I know I'm missing something simple, but I'm about to tear my hair out over this... their website is absolutely no help!
franton
@elsmith sadly I do not. If you find it, please post it here.
elsmith
New Contributor III
@franton Will do! Thank you :) I think I'm close (or maybe I just haven't had enough coffee)
msergi
New Contributor III
@elsmith I am having the exact same problem - I was able to set the portal address using @franton s method (thank you for that) but I cannot get the connect-method setting to work no matter where I put it. using the new 5.2.2 client btw. I think I will have to get my networking team to engage with PAN support unless someone knows the secret sauce
sdagley
@franton Am I imagining things, or did Palo Alto change the configuration back to the 5.0.x format for 5.2.x? (My org skipped the 5.1.x Mac releases)
msergi
New Contributor III
@sdagley I am still having to use Franton's method for the portal address plist file for both 5.2.2 and the new 5.2.3, I am unable to get the connect-method setting to work at all still, even when I place the plist files manually in both preferences folders without using jamf . I am having our network engineers open a TAC case for me on this, I will let you know what I discover.
vickih
New Contributor III
@dan-snelson thanks for your Files and Process Execute Command. And it's much appreciated!
franton
@sdagley No idea. Only just started on 5.2.4 testing ... and I've still got both sets of profiles deployed.
gachowski
I am not able to get connect-method key to work either ... I also think that the setting can be pushed/overridden once the agent's 1st connection is made.
msergi
New Contributor III
After my ticket with PAN I was able to get the connect-method and portal address working, however I had to abandon the config profile and just use a separate Composer Package to drop the plist file in the directory. So I have one stock PKG file to install the client, then a PKG I created to drop the plist in /Library/Preferences. I will paste my plist that worked below if anyone needs it. (This worked for 5.2.2 and 5.2.3)
<?xml version="1.0" encoding="UTF-8"?> <!DOCTYPE plist PUBLIC "-//Apple//DTD PLIST 1.0//EN" "http://www.apple.com/DTDs/PropertyList-1.0.dtd"> <plist version="1.0"> <dict> <key>Palo Alto Networks</key> <dict> <key>GlobalProtect</key> <dict> <key>PanGPS</key> <dict/> <key>PanSetup</key> <dict> <key>Portal</key> <string>YOUR PORTAL HERE</string> </dict> <key>Settings</key> <dict> <key>connect-method</key> <string>on-demand</string> </dict> </dict> </dict> </dict> </plist>
NickGuru
New Contributor III
this worked on my end. i had to kill global protect process then re-launch it.
franton
I've ended up taking the above info, and some of @elliotjordan 's work and come up with this. It sits in the postinstall pkg I wrap around Palo Alto's installer.
# Remove GlobalProtectService keychain item from all users' login keychains.
USER_LIST=$(/usr/bin/dscl . -list /Users UniqueID | awk '$2 > 500 {print $1}')
for THIS_USER in $USER_LIST; do
    USER_HOME=$(/usr/bin/dscl . -read "/Users/$THIS_USER" NFSHomeDirectory | awk '{print $2}')
    USER_KEYCHAIN="$USER_HOME/Library/Keychains/login.keychain-db"
    if [[ -f "$USER_KEYCHAIN" ]]; then
        if /usr/bin/security find-generic-password -s "GlobalProtectService" "$USER_KEYCHAIN" &>/dev/null; then
            /usr/bin/security delete-generic-password -s "GlobalProtectService" "$USER_KEYCHAIN" &>/dev/null
done
# Fix for the GP connecting all the time instead of on demand
defaults delete /Library/Preferences/com.paloaltonetworks.GlobalProtect.settings.plist
rm /Library/Preferences/com.paloaltonetworks.GlobalProtect.settings.plist
defaults write /Library/Preferences/com.paloaltonetworks.GlobalProtect.settings.plist '{ "Palo Alto Networks" = { GlobalProtect = { Settings = { "connect-method" = "on-demand" }; }; }; }'
It's not that sophisticated but it works, and unlike deploying a plist as mentioned above ... it is cfprefsd compatible.
im seeing this on the 6.x client as well. My portal address is pre-configured with a config profile, machine wide, via Jamf. If I set on-demand manually before installing like your script there does everything works fine.
 However if I set on-demand with a config profile it doesn't work, hangs up while trying to auto connect. Any ideas?
franton
Blast. Made a mistake with the copy. The defaults line is missing a ;
defaults write /Library/Preferences/com.paloaltonetworks.GlobalProtect.settings.plist '{ "Palo Alto Networks" = { GlobalProtect = { Settings = { "connect-method" = "on-demand"; }; }; }; }'
bwoods
Valued Contributor
Does anyone have information regarding a Content Filter for Global Protect? I want to prevent the filter prompts that appear during installation.
franton
As far as i'm aware GP isn't installing a content filter, even on latest 5.2.4.
bwoods
Valued Contributor
@franton I'm currently testing Global Protect 5.2.4 on 11.1 and during installation I'm receiving Content Filter prompts that disrupt DEPNotify. Palo Alto provided 4 configuration profiles to get around this issue in addition to the System Extension/Kernel Extension/PCC/Notificaion profile that you need to configure yourself. One of the provided profiles does not install if you are running Jamf Cloud version 26 due to a Jamf Pro issue. Jamf says that the issue should be resolved in the next release.
ceebd6d6ef35494ba7e088366deef733
You may also not see this if your GP Protect Admins have turned specific features such as "Enforcement" off.
smpotter
New Contributor III
@bwoods Could you share the CP's from Palo Alto that allowed you to get around these issues?
Thanks in advance...
bwoods
Valued Contributor
@smpotter contact me on the macadmins #paloalto Slack channel. My name is brndnwds6 on Slack.
Saikat
New Contributor III
I have recently configured for my environment and this solution worked perfectly.
Policies > Files and Processes
Execute Command
/usr/libexec/PlistBuddy -c "Add :Palo Alto Networks:GlobalProtect:PanSetup:Portal string servername" /Library/Preferences/com.paloaltonetworks.GlobalProtect.settings.plist ; /usr/bin/su - "/usr/bin/stat -f%Su /dev/console" -c "/usr/bin/pkill -l -U /usr/bin/stat -f%Su /dev/console GlobalProtect" ; /bin/sleep 3 ; /usr/local/bin/jamf recon
Post installation, it updates the server name and works great.
OmarJ
New Contributor
@Saikat thanks for sharing, how would you add the CERTIFICATESTORELOOKUP= "user and machine" key? would that be possible with this method?
mmunoz
New Contributor
Hi everyone, so been trying to set this up for a few days and can't figure it out. the documentation from PA is not really clear, so far I have tried everything that was suggested here but no luck. And when I made changes to the Plist the address only gets added after a reboot. am I missing something?
