Help with Firefox CIS Benchmark plist deployment
  • June 18, 2024
  • 4 replies
  • 46 views
I'm trying to put together a CIS lvl 1 plist for firefox deployed via JAMF pro and unsure which compliance options are related to which keys in the plist, or where to start beyond adjusting the standard plist, does anyone have any resources to aid with this? or a baseline plist to share?
Hello,
Crafting a CIS lvl 1 plist for Firefox on JAMF requires mapping CIS settings to plist keys. First of all find the CIS Firefox Benchmark. Look for the settings mapped to registry keys - these keys translate to plist settings for Firefox profiles. JAMF uses plists for configuration. Integrate the Firefox profile plist into your JAMF plist.
Check JAMF's documentation for details on configuring Firefox profiles with plists.
I hope the information may help you.
AJPinto
  • June 18, 2024
Generally speaking, CIS level 1 or level 2 does not usually get into application configuration itself. It's mainly OS hardening, and monitoring for malicious and vulnerable configurations.
This is the macOS Security Benchmark, there won't be anything for Firefox or really any other application on it. The docs found here will walk you through configuring everything to meet the various NIST benchmarks.
GitHub - usnistgov/macos_security: macOS Security Compliance Project
Jamf also has a tool to help automate creating the configurations for CIS level 1 and level 2, however use it with caution as it does not check to see what is already configured elsewhere.
Establishing Compliance Baselines (jamf.com)
boberito
Forum|alt.badge.img+22
  • June 19, 2024
@AJPinto CIS has benchmarks for browsers as well.
  • June 19, 2024
Hello,
thanks for this, this is exactly what I ended up doing, just a bit of trial and error with mapping the .cfg file entries into .plist and getting the values and dictionaries in the right place
thanks for everyones help!
