Posted on β11-26-2018 07:40 AM
Hi I am currently been testing High Sierra and only have one issue left to get working.
I am using the script below fine on Sierra and its working and applying fine.
But under High Sierra its running but not working, and as i can tell not creating the com.apple.SetupAssistant.plist files and amendments.
The output result from the script is :
Script exit code: 0
Script result: chown: Deleted Users: illegal user name
Am abit above my coding level to work out what they have changed in High Sierra to stop this working.
Thanks to all for any help and i think the script came from @rtrouton originally, but has been modified slightly for High Sierra
Cheers
# Determine OS version and build version
# as part of the following actions to disable
# the iCloud and Diagnostic pop-up windows
osvers=$(sw_vers -productVersion | awk -F. '{print $2}')
sw_vers=$(sw_vers -productVersion)
sw_build=$(sw_vers -buildVersion)
# Checks first to see if the Mac is running 10.7.0 or higher.
# If so, the script checks the system default user template
# for the presence of the Library/Preferences directory. Once
# found, the iCloud, Diagnostic and Siri pop-up settings are set
# to be disabled.
if [[ ${osvers} -ge 7 ]]; then
for USER_TEMPLATE in "/System/Library/User Template"/*
do
/usr/bin/defaults write "${USER_TEMPLATE}"/Library/Preferences/com.apple.SetupAssistant DidSeeCloudSetup -bool true
/usr/bin/defaults write "${USER_TEMPLATE}"/Library/Preferences/com.apple.SetupAssistant GestureMovieSeen none
/usr/bin/defaults write "${USER_TEMPLATE}"/Library/Preferences/com.apple.SetupAssistant LastSeenCloudProductVersion "${sw_vers}"
/usr/bin/defaults write "${USER_TEMPLATE}"/Library/Preferences/com.apple.SetupAssistant LastSeenBuddyBuildVersion "${sw_build}"
/usr/bin/defaults write "${USER_TEMPLATE}"/Library/Preferences/com.apple.SetupAssistant DidSeeSiriSetup -bool TRUE
/usr/bin/defaults write "${USER_TEMPLATE}"/Library/Preferences/com.apple.SetupAssistant.plist DidSeeSyncSetup -bool true
/usr/bin/defaults write "${USER_TEMPLATE}"/Library/Preferences/com.apple.SetupAssistant.plist DidSeeSyncSetup2 -bool true
/usr/bin/defaults write "${USER_TEMPLATE}"/Library/Preferences/com.apple.SetupAssistant DidSeeApplePaySetup -bool false
/usr/bin/defaults write "${USER_TEMPLATE}"/Library/Preferences/com.apple.SetupAssistant DidSeeAvatarSetup -bool false
/usr/bin/defaults write "${USER_TEMPLATE}"/Library/Preferences/com.apple.SetupAssistant DidSeeCloudDiagnostics -bool false
/usr/bin/defaults write "${USER_TEMPLATE}"/Library/Preferences/com.apple.SetupAssistant DidSeeTouchIDSetup -bool false
/usr/bin/defaults write "${USER_TEMPLATE}"/Library/Preferences/com.apple.SetupAssistant DidSeeiCloudLoginForStorageServices -bool false
done
# If so, the script checks the existing user folders in /Users
# If the directory is not found, it is created and then the
# iCloud, Diagnostic and Siri pop-up settings are set to be disabled.
for USER_HOME in /Users/*
do
USER_UID=`basename "${USER_HOME}"`
if [ ! "${USER_UID}" = "Shared" ]
then
if [ ! -d "${USER_HOME}"/Library/Preferences ]
then
/bin/mkdir -p "${USER_HOME}"/Library/Preferences
/usr/sbin/chown "${USER_UID}" "${USER_HOME}"/Library
/usr/sbin/chown "${USER_UID}" "${USER_HOME}"/Library/Preferences
if [ -d "${USER_HOME}"/Library/Preferences ]
then
/usr/bin/defaults write "${USER_HOME}"/Library/Preferences/com.apple.SetupAssistant DidSeeCloudSetup -bool true
/usr/bin/defaults write "${USER_HOME}"/Library/Preferences/com.apple.SetupAssistant GestureMovieSeen none
/usr/bin/defaults write "${USER_HOME}"/Library/Preferences/com.apple.SetupAssistant LastSeenCloudProductVersion "${sw_vers}"
/usr/bin/defaults write "${USER_HOME}"/Library/Preferences/com.apple.SetupAssistant LastSeenBuddyBuildVersion "${sw_build}"
/usr/bin/defaults write "${USER_HOME}"/Library/Preferences/com.apple.SetupAssistant DidSeeSiriSetup -bool TRUE
/usr/bin/defaults write "${USER_HOME}"/Library/Preferences/com.apple.SetupAssistant.plist DidSeeSyncSetup -bool true
/usr/bin/defaults write "${USER_HOME}"/Library/Preferences/com.apple.SetupAssistant.plist DidSeeSyncSetup2 -bool true
/usr/bin/defaults write "${USER_HOME}"/Library/Preferences/com.apple.SetupAssistant DidSeeApplePaySetup -bool false
/usr/bin/defaults write "${USER_HOME}"/Library/Preferences/com.apple.SetupAssistant DidSeeAvatarSetup -bool false
/usr/bin/defaults write "${USER_HOME}"/Library/Preferences/com.apple.SetupAssistant DidSeeCloudDiagnostics -bool false
/usr/bin/defaults write "${USER_HOME}"/Library/Preferences/com.apple.SetupAssistant DidSeeTouchIDSetup -bool false
/usr/bin/defaults write "${USER_HOME}"/Library/Preferences/com.apple.SetupAssistant DidSeeiCloudLoginForStorageServices -bool false
/usr/sbin/chown "${USER_UID}" "${USER_HOME}"/Library/Preferences/com.apple.SetupAssistant.plist
done
Posted on β11-27-2018 06:38 AM
Sorted now it was due to an account being deleted and then Backed up to a folder called Deleted Users in the Users folder.
We have changed this now than any deleted users go into /Users/DeletedUsers and the error has now resolved so must have issues with spaces in usernames in that folder.
