High Sierra Mobile Accounts
morgan_sd51
New Contributor II
Is anyone else having issues logging into mobile accounts on High Sierra?
We are not able to login to any of our AD accounts with "Create mobile accounts at login" enabled
whenever we log in we get the message, "You are unable to log in to the user account "morgan" at this time. logging in to the account failed because an error occurred"
Anyone have any ideas or is anyone experiencing the same issue?
41 REPLIES 41
bmcdade
Contributor
@Tophernad Nope, we stopped looking for a solution from Apple and started to work on rolling out Jamf Connect Login (using Okta). We attached our LDAP to Okta, and now the plan is that it will be the provider.
Tophernad
New Contributor II
@bmcdade Thanks for the info. We are working towards Nomad Login AD.
