Hosted JSS issues
  • January 15, 2016
  • 13 views
Anyone with a hosted JSS seeing issues where they cannot edit certain types of objects such as polices or configuration profiles. ?
I can open a policy and see it's current configuration but when i click the edit button I get the spinning wheel and then the page goes blank where the configuration should be.
I've checked and it's not my permissions in the JSS as I have all the correct rights, I've also had a colleague check and he also has the same rights, is experiencing the same issue.
I can't see anything on the JAMF site about service status etc.
Thanks in advance.
Best answer by admin13
@AlistairCarr
If you go to Global Management >> Categories, do any of your categories have a single ' in the name?
If so, it's possible that you're running into a currently known issue (D-010067), and the workaround is to rename the category so that it does not have a ' anywhere in the name.
The only caveat with doing that is that, if you have any API scripts that call the category by name, they will also need to be edited to reflect the edited category name.
If you don't have any categories with a ' in the name, then it's likely something else is going on and you'll want to get in touch with your Technical Account Manager to dig into it a bit deeper.
Amanda Wulff
JAMF Software Support
  • January 15, 2016
Expected behaviour.
Bottom section of this article talks you through reducing the image size.
https://support.apple.com/en-us/HT202841
Or use Carbon Copy Cloner to create the image as it should create a sparse image.
  • January 15, 2016
@AlistairCarr
Amanda Wulff
  • January 17, 2016
Amanda you're a star !!!
Thanks ever so much for the info !!
